richee2000
I see Edison PD Dispatch has been added to the DB, on the Middlesex Co TRS showing "Te" Is this correct? (are they in the clear?)
The PD Dispatch talkgroup has been in the database since April, it was not added today.I see Edison PD Dispatch has been added to the DB, on the Middlesex Co TRS showing "Te" Is this correct?
my question was: are they in the clear? since it says TeThe PD Dispatch talkgroup has been in the database since April, it was not added today.
Lower case "e" indicates partial or part-time encryption, not "in the clear". Perhaps the source who submitted it will chime in, but that's how it was submitted.
Could you not just listen to it for yourself to verify?
If I could receive the system, I would not be asking the question on here...... I was under the impression that Te meant Encryption could be activated, at will, but not Strapped Fully E. (so that would indicate comms could be in the clear)
Richee, I could be wrong, but I also take it to mean 1-sided E. North Haledon(last time I listened), and Ringwood on their simplex NXDN frequency, had dispatch encrypted, but portables/mobiles in the clear.
From the database administrator handbook:
The intent of the lower case e is to indicate that encryption is selectable/optional, not to indicate that a few clear transmissions were heard because a radio was programmed wrong. If the channel/talkgroup is meant to be secure, then the upper case E should be used, regardless of whether a clear transmission sneaks through every blue moon.
Edison has no future plans to build out any sites, nor the County. They are on the County TRS to stay. Using RF engineering propagation tools you cant add anymore sites with out causing self interference.Edison 5 Site P25 TRS has filed the required yearly report for an extension. Reading this it is not clear what the future holds.
The County built (2) new sites in Edison for Edison. Surely Edison won’t be leaving the County TRS?
Sub sites to be built perhaps to be absorbed by the County using the Edison license? @X9009X
https://wireless2.fcc.gov/UlsEntry/...tachmentKey=21915814&attachmentInd=applAttach
Thanks, must be kicking the can down the road, keeping spectrum.Edison has no future plans to build out any sites, nor the County. They are on the County TRS to stay. Using RF engineering propagation tools you cant add anymore sites with out causing self interference.
