Editing text.
TreeTall
Granby
Cannot find anywhere how to select a letter after selection is made.
At ‘Confirm?’ press E/ .6. At ‘Edit Name’ press E/ .7. Scroll to ‘Edit Sys Option’ and press E/ "
cmjonesinc
Knowing what scanner you are asking about would be helpful. I know with the bcd996xt you just spin the dial.
From the easier to read manual
To enter a letter, turn the scroll control until the character you want appears.
(character order clock-wise is upper-case, lower-case, numbers, then special characters).
To enter a decimal point, press .No.
To move the cursor to the right, press 6.
To move the cursor to the left, press 4.
To clear a character or enter a space, press .No.
To clear all characters, press .No twice.
Press E/● when finished to exit.
Press the 'Back' button in your browser to return to programming.
If you haven't done so already, find the easier to read manual for your radio from Mark's scanners. Use ctrl+f to search through it if needed.
