EF Johnson 5100
chudson584
Jasper, AR
How do you switch a EFJ 5100 from analog to digital? I bought one and had the company program it for me and it's in analog mode. How do I put it in digital? I do not have the software or cable. It is front panel programmable.
buddrousa
The 5100 51SL 5300 EF Johnson radios have to programmed as a digital channel you have to have each channel programmed Analog and Digital. Channel 1 analog channel 2 digital ect.
chudson584
Jasper, AR
So do I have to program in alternating order as you said. One channel analog, the next digital, then analog, digital, analog...and so forth? Or can I just specify a whole zone to have all digital back to back?
buddrousa
No you just to have the radio programmed analog channels and digital channels any order you wish you will also have to program the NAC code for each digital channel also.
Curtis36l
i own a ef johnson 5100 and have the programming cables and use pc config 2.10.2 and when i look at radio it flashes bad band at me all the time and cant be programmed. is there a way to correct this
