Not hard to install inline almost anywhere in the feedline, and certainly having it won’t hurt anything. This was just the minimalist in me taking the “KISS” approach.
This is really common in installations that have no counterpoise since the feeder screen is forced to become that counterpoise. One can often get away with doing this by using a feedline choke or similar a little way away from the house but a counterpoise of some reasonable size it pretty much required.I've had a myantennas 40-10 EFHW up for a while now and love it. You'll want to be aware EFHW's produce a lot of RF that could cause issues in the house if it is close enough. Mine was turning my oven on and off. I had to move it further out and put an RF choke on it.
In this video, Dave Casler uses the MyAntennas 4010 EFHW as the example and says whether or not you need a counterpoise will be dependent on the length and grounding of your coaxial feed line. In his case it was 50 feet.... and he says the counterpoise was unnecessary.
At any length at all you will be causing RF on the feeder screen; at reasonable output powers you are likely to have problems with RF getting into the shack. At some lengths things will be better but a hot screen will usually result.In this video, Dave Casler uses the MyAntennas 4010 EFHW as the example and says whether or not you need a counterpoise will be dependent on the length and grounding of your coaxial feed line. In his case it was 50 feet.... and he says the counterpoise was unnecessary.
These are good. I have two. I found that if installed at the transformer my EFHW 4010 antenna became useless. Works fine with choke about 10 feet away just before the coax enters the house. I still have RF in the house because I set it up as an inverted L over the house. My EFHW 8010 is away from the house and gives no RF problems.Thanks for the info. Would something like this at the antenna solve this problem ?
The purpose of the choke is to keep RF off the feedline and from getting to your radio making the chassis and any connected wires hot with RF. An EFHW operated within resonance has little RF on the coax but used out of band it can get pretty bad. It’s also nice to have a little coax counterpoise on an EFHW so I like to place the choke balun about 20ft down the coax from the transformer. This has worked well for me and I’ve tested it on many band edges with good results. The key is to have a very effective choke balun made with ferrite and not some coax wound into an air choke.Maybe i was not clear, i do have the choke and i will install it. My question pertains to the choke location. Should i install it near the feed point or where the coax enters the house ?
I tie a 1/4" rope around the tree just above a big branch with a pully attached and enough slack to allow for tree growth. Then I run another 3/16" or 1/4" thick rope from the antenna insulator (far side away from the transformer) through the pully then to a weight made from pouring concrete in a small bucket with an eye bolt sticking out the top.Hello again,
Need some advice here. I will soon be installing the antenna. At some point the wire will need to be attached/supported to a fir tree. I get that i will need to accommodate for the sway of the tree but i'm not sure how i should do it. Any suggestion ?
Many thanks
73 De VA2FCS
Tie the weight on so it sits a couple of ft above ground or high enough for when the tree sways toward the antenna the weight doesn't hit the ground. For a 133ft wire antenna about 50lbs of weight is good and for a 64ft maybe 30-40lbs. I use black Dacron rope that has the woven sheath over a bundle of strands, it lasts a long time.
Two legs meeting the tree sounds like you might be doubling back the antenna on itself. If you put a bend in the wire make it less than 90deg or find another location, running the wire out then doubling back with less than a 90deg bend can really reduce antenna radiation and efficiency.Thanks for the info but i think my question was not clear. I was not talking about the far end of the antenna. The configuration of the antenna will be a horizontal V and i trying to figure out how i will attach the the point where the 2 legs of the V meet to the tree. The pulley solution will be easy to implement for the far end of the antenna.
