Emergency Frequencies Are All Just Static
cschoe
Louisville
Hi! I'm new to radio in general and picked up an SDR radio kit today so I could tune into police dispatch. I've found my county's emergency frequencies (Louisville Emergency Communications Network: MetroSafe Trunking System, Multiple, Kentucky) but although I can see noise appearing at those frequencies, when I tune it only ever sounds like noise. Is there something obvious I'm doing wrong? So far the only thing I've been able to listen to is a few music stations.
chrismol1
P25 TruCking!
You will need to use SDRTrunk program and input the red control channel so it will follow the voice channels
a417
just to forewarn you...
of the sample of 10 of the talkgroups that are broadcast on that trunked system, you will be able to pick up only one of them. You will notice that column of 'DE' - which means fulltime digital encryption is in use on those channels. The 'All Talk' group is the only one there that's not currently blocked from you.
Good luck.
sunwave
Oklahoma
DSD-FME for APCO P25 works well for C4FM type systems. SDR++ has it's own RIGCTL and AUDIO over TCP plugins which makes it easier to get up and running. APCO P25 is digital and digital always sounds like noise. That's the reason we use decoders.
maus92
The OP
Wrong tool to use to monitor the system. SDR Trunk is probably the easiest for a novice to set up but will require several RTL-SDRs or a single AirSpy.
dave3825
Suffolk County NY
While his screenshot does reflects a freq from the first site (or close to it), if he was able to receive any of the last three sites, he could get buy with 1 dongle.
RFSSSiteNameCountyFreqs
1 (1)001 (1)Jefferson County SimulcastJefferson854.2125c854.4875c854.7375c855.3625c856.2125856.4375856.4625
856.7625856.9375857.2125857.4375857.4625857.7625857.9375
858.2125858.4375858.4625858.7625858.9375859.2125859.4375
859.4625859.7625859.9375
1 (1)003 (3)Jeptha KnobShelby851.475852.475852.950853.225c853.875c
1 (1)004 (4)La GrangeOldham851.1375851.350851.675852.100852.2875c852.625c
1 (1)005 (5)New BernheimBullitt851.6375851.8875852.1375852.3875c853.125c
