EMRC
maus92
OCMD
You can, but your issue is likely what was explained earlier - the UHF MED channels are duplex, meaning the base stations transmit on one frequency, and the mobiles transmit on another. You are more likely to hear the base station as its antenna is taller and uses a higher power radio. In STMC, you only need to program frequency pairs for MED channels used in the county.
maus92
OCMD
Not much anymore as most public safety radio in Maryland is on an 800 or 700 P25 trunked system.
R8000
Very Low Battery
I think they should patch the FIRST & county TGs onto the uhf
Why?
That would sound awful. Analog to digital patching rarely every sounds good and in this case would just tie up shared channels with other states.
Firemantincan
SYSCOM still works on 44.74 . Don't know if the VHF low air med patch still works or not. SYSCOM on the state FIRST system works and so does Helimed 1.
Also, the med patches on the Calvert system are encrypted. SMC has active med patches on the FIRST system, but I don't think the SMC units are using them as their normal comms method. As far as I know they still use the UHF duplex system.
There are a few other medevac helos you can hear too, like Medstar for example.
FMARS (AKA VFIRE21) 154.28 is pretty fun. There used to be some fun stuff on the 8CALL and 8TAC frequencies (PL 156.7), but I haven't heard much on those in a long time now.
Theres a whole world out there. You just have to find it and decipher. Most stuff you'll pass by an never even notice it. P25 Phase 2 is a big deal right now. DMR is pretty cool. If you're not using a digital radio or an SDR than you're missing a lot.
jimmymumper
Lexington Park
I havent upgraed my pro35 to have 800 MHz yet
maus92
OCMD
Also, Region IV still uses the UHF Med channels - I believe Talbot Center is the control point. So if you are on the lower Eastern Shore, it would be worth monitoring them. Keep in mind that they were narrowbanded a while back, and I wouldn't bother with programming a tone code.
maus92
OCMD
The points are UHF is still used, and narrowbanding could be part of your issue.
maus92
OCMD
No, never use a radio that can potentially transmit to monitor a public safety system- a huge no-no.
