EMS / FD Tone's
Leavenworth, Ks
A member of my group sent me their BCD325P2 scanner to program & i programed it how they wanted it to be programed, now my question is this why do i have to program the EMS / FD tones in the BCD325P2 ? i did not have to program the tones in my Pro 106 or WS 1040, why is there a difference in scanner's ?
a417
programming tones into a radio (or to a limited extent a scanner) usually allows you to tailor alerts only for the agencies you program in.
If you do not program in anything, most radios will just blurt out whatever they hear on that particular frequency. It will be listening CSQ, and will unmute on any valid carrier on it. If you use a signalling system (MDC1200, QC-II, SelCall, etc) then the unit will usually mute out the radio calls that are not preceeded by that signalling protocol, and you will not hear them. If you program in a particular tone-set correctly, the radio (or a scanner) will usually alert you when that tone set comes across, and then unmute the channel.
Individual radios (and scanners) have varying methods of programming how they unmute on tones (signalling squelch), so it will vary widely. Most people who are using a specific device like a scanner will use it to listen CSQ to a channel, as they want the multifunction aspect of it. Most units, when will check for a 1) a valid signal on that frequency and then 2) a matching signalling protocol on that frequency, before they unmute...and this usually instills an undesirable delay in the responsiveness of a unit. Ok for the light duty hobbyist, but a terrible way for a person to rely on it to be notified of a timely dispatch or a specific call.
ofd8001
Louisville, KY
In other words, Fire Tone Out means the scanner is acting just like a tone and voice pager does. It only operates when the programmed alert tones are activated on the programmed frequency.
It is a nice option, but not critical to general scanning.
