Encrypted Talkgroups
Citywide74
MARYLAND
I am asking, and I am sure that I am not alone, that any talkgroup that is listed as encrypted be removed from the program that is used by Uniden to program the full database into the scanners. If they are encrypted they are no good to scanner monitors. I'm not sure but I can't believe Whistler is any different
RayAir
It should be up to the scanner listener if they want those TGs in their scanner or not.
I've found some of the TGs listed as being encrypted are actually not.
Others operator error occurs frequently on.
The ones that are strapped, the scanner user can leave them out.
WX4JCW
Stow, Ohio
the new ARC536 from Butel will filter ENC talkgroups and add the LED Light as well
I would prefer them left in and the end user can temporary avoid or permanently avoid them.
mikewazowski
Forums Manager
Oot and Aboot
Moved. This has nothing to do with RadioReference or its administration.
UPMan
In Memoriam
Arlington, TX
First releases of the dB omitted ENC channels. Got lots of complaints. So, now we include them. Get fewer complaints. Mode with fewer complaints wins.
campd715
Southeastern Connecticut
ENC UID display-please
Now if only Uniden would allow ENC UID's to display in the 536HP I'd be even MORE happier than I presently am I personally would not have any need to complain.
Dennis
QUOTE=UPMan;2630351]First releases of the dB omitted ENC channels. Got lots of complaints. So, now we include them. Get fewer complaints. Mode with fewer complaints wins.[/QUOTE]
ofd8001
Louisville, KY
Upman: would you mind confirming this is indeed happening? The Louisville MetroSafe system shows a number of encrypted talkgroups in the RR database, however these did not show up in the 8/19 data pull. Louisville Emergency Communications Network: MetroSafe Trunking System, Multiple, Kentucky - Scanner Frequencies
FWIW, I agree with the including them as there are some systems I monitor where encryption is part time.
