The way I understand the charging process, a battery should always remain as cool possible, or at most warm to the touch, during charging because high temperatures shorten battery life. However, some temperature rise cannot be avoided. If the batteries are too hot too touch while being charged, I don't think that is a good situation.
Fast chargers, such as the Energizer 15 minute, usually generate high temps in the batteries being charged. The Energizer charger claims to limit the temps of the batteries, but it doesn't say what the temp limit is. While we all like fast recharge times, we are actually cutting down on the number of times the battery can be recharged, maybe by as much as 2-3 times. The higher rated batteries (2500mAh and up) have about 500 recharge cycles maximum under ideal conditions. Shortening total battery life is great for Energizer, since they sell more batteries that way. I do think that Energizer rechargeable batteries are very good, but I just prefer a good charger that charges at a slower rate (2-4 hours) with controls to limit overcharging and over temp conditions. I would suggtest buying several sets of batteries; that way you don't have to care how long the recharging takes.
I also agree with the previous post about monitoring the fast chargers if you use them, as I have had NiMH rechargeables overheat and leak when the charger protection circuit failed. A definite potential fire hazard.
I have been using a Lightning Pack 4000N charger for over 2 years with excellent results and reliabilty.
http://www.ripvan100.com/products_recharger.htm
Dave
