Entergy code plug for whistler tx-1
k5wc
Lonoke, AR
Would anyone mind sharing a code plug for entergy for a whistler tx-1? I can load AWIN just fine in the whistler software under library import but the entergy system doesn't show up for Arkansas trunk systems. Any help is much appreciated. It's very possible that I am not doing something correctly, but I'd hope not to have to enter the system in manually in the software. Thank you in advance. John
03msc
RF is RF
The Natural State
I don't use Whistler scanners anymore, but I was helping someone the other day and noticed that Entergy wasn't showing up. I know in the db on here it is listed as a multi-state system...not sure if that has something to do with it or not. I say that to say you're not doing anything wrong.
In EzScan if you go to the import screen, use Preferred import, go to Ark, select Agencies, then Public Utilities it will come up.
k5wc
Lonoke, AR
When I do that it only shows two conventional channels, not the Apco P25 trunked system. I would have expected it to show up under Arkansas and trunked systems.
k5wc
Lonoke, AR
I've even checked Texas and Louisiana to see if it was over there. First whistler I've ever tried to program, all my other scanners are uniden. Thanks
My apologies for not checking the final step. Okay, still use preferred but go to Texas, Jefferson County, and Trunked systems.
