Error Message When Programming
ThePhotoGuy
Maryland
My G4 has the previous Phase II firmware (Haven't tried latest firmware yet).
So I go into the PPS to program my radio. After I hit program, it runs for about 3 minutes and then error message comes up, saying something like "Out of Bounds." I then click okay and then try to program the radio again. As I hit program again then my computer "Microsoft Windows" says that an Error has occurred and the computer needs to restart.
First time seeing this. Not sure what the error was with programming the radio and then what the the error was on my computer and needed to restart?
ThePhotoGuy
Maryland
Just tried updating again and got the same message...
troymail
Silent Key
I've seen this at times but only at times where I didn't program everything "by hand" using the PPS. Can you send me a copy of the configuration? Check you PMs.
ThePhotoGuy
Maryland
Sent you a copy.
Update:
On the 3rd try it finally programmed. Waited again and tried a 4th time to see if it would continue to program and it did. Not sure why it didn't work before and then made my computer restart.
