I've run one feed successfully for a while.
Second one is approved.
Hardware: Same computer; two sound cards; one scanner per feed, one on each sound card.
Software:
Scannercast was reconfigured and sees "both" feeds from broadcastify and I can swap between the two.
I used the command line to create a second scannercast.ini file for the second one.
On first run of the second feed, i allowed it thru the firewall like I did the first time.
HOWEVER, i'm getting a "exception starting server, port number on config tab is probably invalid" error
I have confirmed both instances are sending data to the correct feed. Clicking thru the error, it *looks* like both are transmitting. They are sending to unique servers (audio3 and audio9) and both feeds appear to be online.
Am i doing something wrong here?
Software:
