Error starting DSDplus
Bonkk083
Union, SC
When I try to start FMPA.CC I get a error it says invalid Airspy but the serial number is correct in FMPA.CFG
Bonkk083
Union, SC
Do I need to get all frequcies or just the CC, I'm having trouble with SDRtrunk
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
The threads about DSD plus and now you’re throwing in SDR trunk. What’s up with that?
If it’s P25 you don’t need all the frequencies, just the control channels. For most DMR and NXDN systems you will need to know all of the frequencies and other information. Of course, SDR trunk doesn’t do NXDN so you would not be talking about that
Bonkk083
Union, SC
I need help understanding these settings and how should should be set
Screenshot 2024-11-09 010521.pngScreenshot 2024-11-09 010551.pngScreenshot 2024-11-09 010647.pngScreenshot 2024-11-09 010708.png
mtindor
FMP24 PRO USER
View attachment 172514View attachment 172515View attachment 172516View attachment 172517
First of all, I have noticed many many times that if I limit the number of "Decode" types, eventually it stops decoding what I have it set to decode and then I have to toggle "Decode All Above Protocols". As such, I would really suggest that you set it at its default, which is "Decode All Above Protocols"
Everything is set correctly for normal operation.
Run FMP*-CC.exe and 1R.bat
dave3825
Suffolk County NY
I have seen this also and also have seen it resume decoding by toggling Decoding Polarity Auto Detect on and off.
mtindor
FMP24 PRO USER
Interesting. Never thought to try that. I'll probably leave mine like it is (decoding all), but it's nice to know that toggling Polarity Auto Detect fixes it too. Next time that I restrict what is decoded and run into that, I'll try what you suggest and see what happens.
