Etrunker Modification Help Needed
I would like to disable the "d" and "v" items that show up on the left hand side of the Etrunker screen. I have added the LCN numbers (on the left) of my system file, and removed the d and v item from the same file. This is fine, but I would like to have the d (data) and v (voice) items not show up .. but the changing of the colors is fine. The d and v of course are filled in as each LCN is used.
Anyone know what C file i need to change .. ? I realize I probably just have to comment something out .. but cannot find the code that causes the D and V to go to the screen.
I am really interested in seeing the LCN on the screen rather than whether it is data or voice.
Hope this makes sense .. :?
Kevin
Look in file named "FREQDISP.CPP for the following ...
Code:
void
frequencyAssignment::assignD()
        if( fState == FREQDATA) {
                visited = TRUE;
                return;
        if( fState != FREQEMPTY ) {
                unassign();
        // nothing to data channel
        freqdisp[1] = 'd';
        fState = FREQDATA;
        visited = TRUE;
        dirty = TRUE;
        selected = FALSE;
... and also ...
Code:
void
frequencyAssignment::setMaxType(CallType t, designation *d1, designation *d2, designation *d3)
        if( maxType != t ) {
                if( maxType != Idle) {
                        unassign();
                freqdisp[2] = 'v';
                seenVoice = TRUE;
                fState = FREQCALL;
                maxType = t;
-rick
EricCottrell
Boston, Ma
Hello,
You also have to change the code that writes the sys file. There is code that will write out a frequency line in the sys file only if any of the c d v flags are set.
73 Eric
