EX-S24 with Brandmeister
HowardSmall
Kuranda, Qld, Australia
I have programmed my EX-S24 to work with Brandmeister via my MMDVM hotspot. Everything works except I do not have any audio when receiving. I have both the EX-S24 and and FDP DMR radio programmed. With both I can transmit to the Australian Brandmeister Parrot and both receive the signal back. Trouble is the FDP gives audio but the EX-S24 has a flashing green led indicating RF is being received but there is no audio.
I have searched every possible setting and cannot find the cause of the problem. If anyone has experience with programming these radios can you please offer your suggestions?
Thanks,
Howard, VK4BS
dickie757
Wired
Out of range
Might be an ID issue. Do the radios work with each other? Is it a duplex hotspot? Color code correct? Timeslot? When you talk to Polly, is it a programmed channel, or manual TG select? Get the radios to talk to each other, or a different repeater to narrow potentional issues.
HowardSmall
All seem correct - hotspot simplex, TS 1 on both radios, programmed and manual TG select, have not tired the radios talking to each other which may give a clue so will try that, thanks.
HowardSmall
Well I have it working now. There are many settings in the CPS for this radio that are quite obscure and it took me, literally, hours to get it all sorted out. If anyone else gets their hands on one of these they may find the attached images helpful when programming. By the way, they are a neat little radio and I was lucky to pick one up in new condition at an auction for AUD75.
