The new noise blanker does not work well against CODAR, but it does work well against things like the Chinese OTHRs that plague the 5500 to 11000 range, there can be as many as 8 of them up in that range at any given time, and the PLUTO radar. As I am writing this there is one of the Chinese OTHRs setting around 6820, and the NB is knocking it down greater than 20 dB, making the Ute on 6823 completely copiable, and without the NB on you cannot even tell the Ute is present.
The slow sweep of the CODAR and similar radars is not rapid enough for the NB to attack it, it sounds too similar to possible audio.
As far as ALE goes, it will not remove that, but then nothing will that I know of. Do you happen to have a recording of what you are calling the "ALE sounder"? There is such a thing as sounding in ALE, but the way you say it makes me think what you are referring to is something else. Unless you are running a decoder and looking at the ALE at the time it sounds you cannot tell, by ear, a sounding from a full up ALE link.
T!
