Excel Import into Armada.
2wayfreq
NM Kirk City
Just Curious,
I have a large amount of conventional frequencies to add to a Viking VP8000 conventional system in bulk (Several Hundred). Has anyone copied/pasted or imported frequencies and other columns from an Excel .CSV? I'm trying to avoid the tedious manual entry.
tweiss3
Is it time for Coffee?
Ohio
Yes, if you go to the table input, make sure you format correctly. You can do either everything, or one column at a time.
n7maq-1
Oregon
Yes, as Tweiss3 said, use the Table. You will first want to add the number of zones and channels you need. Then you can go to table and do 1 zone at a time or all zones by selecting "ALL" at the zone tab. You also have fill down function in Table mode. It is very intuitive, it just takes a bit of practice.
