explain this antenna phenomenon
wenzeslaus
I have a piece of coat hanger. 2' long and straightened out.
if I connect it to the telescopic antenna with a wire, reception improves. no surprise.
but if I don't use that, just use a 2' speaker wire instead, stretching it out to the same length and orientation as the coat hanger was, reception barely improves.
why is that?
wenzeslaus
I took another look. yes, sometimes reception improves when you touch the antenna. no, it wasn't the case here. what I did find out is that the wire used to connect the coat hanger to the antenna, was contributing to signal strength even though it was sort of wrapped up.
touch the coat hanger to the antenna without the wire and it was the same as the wire alone.
so, never mind.
