external sound cards
wa9cat
currently have a p25 feed online and it seems I may be able to improve my feed quality if I switch to a external sound card rather than the internal sound card I am now using in my hp 750
been researching external sound cards and have not been able to draw any clear conclusion on which external sound card to go with . See that the price range is from $8 and up. the radio I am using to provide the feed is a unication G4. Read the description on a few sound cards that they improve speech... dont know if that is for real or just the hype to sell the card. so questions are has anyone any input whether I could improve my audio quality on my feed by switching sound cards or am I wasting my time and money in trying to do that.... and of course if yes.... which external card would be recommended on a windows systems
the bottom line here is since I am using a pretty good radio for the oasis p25 system in the milwaukee area, I would like to use the radio to its full potential on my feed
Hit_Factor
Saint Joseph, MI
I can't give you any recommendations other than you will get what you pay for.
Replacing the onboard with an $8 card is unlikely to produce better sound, nor hardly worth the time to configure and evaluate.
Not knowing what I don't know, I would probably jump in with a $50 card and go from there.
Hopefully someone has chipset or model information that helps you find better sound.
73, K8HIT
Icom: IC-7300, IC-PW1, ID-5100A, ID-51A Plus 2, IC-R30, Hytera PD782G, Kenwood TH-D74, Uniden SDS100, DVMega, SDRplay RSPduo
Kingscup
flythunderbird
Grid square EM99fh
I tried one of the $7.50 Sabrent USB audio adapters on one of my feeds, and in my case it introduced a lot of noise. Never did figure out why, so it was replaced with a Behringer UCA-202 USB audio adapter. The Behringer adapter introduces absolutely no noise, but it does cost $30.
https://www.amazon.com/Behringer-U-Control-UCA202-Ultra-Low-Interface/dp/B000KW2YEI
I use it for both of my feeds. Give it a listen if you like :) ...
http://www.broadcastify.com/listen/feed/18474
http://www.broadcastify.com/listen/feed/20203
wa9cat
I did end up getting an external sound card. Creative sound play 3. Price on amazon has dropped to $18. Sound for me from the external sound card much clearer than the internal sound card. Thanks for the suggestions.
