BC125AT: external speaker for bc125at
magic_lantern
is anyone using a external speaker for their bc125at, if so do you know what the pin out for the plug is and is any particular impedance speaker needed.
thanks
D31245
FN42
I also have a BC125AT and miss having a larger speaker. I am still researching. Here is what I found through Grok:
________________
For the Uniden BC125AT scanner, a good external speaker enhances audio clarity and volume, especially in noisy environments like vehicles or busy settings. Based on available information and user feedback, here are some recommendations and considerations for choosing a suitable speaker:
### Recommended Speakers
1. **Uniden BC20 Bearcat 20-Watt External Speaker**
- **Why it’s good**: This non-powered 20-watt speaker is praised for its crystal-clear audio and robust design, making it ideal for amplifying the BC125AT in both home and mobile setups. It features a noise blanker to reduce electrical interference and a 4.5-inch speaker with a frequency response of 300Hz-5kHz, optimized for communication clarity. Users report it provides a significant volume boost and clearer sound compared to the scanner’s internal speaker.[](https://www.amazon.com/Uniden-BC20-Communications-Amplifying-Receivers/dp/B009TNABQ2)[](https://singersroom.com/music-gear/best-external-cb-speakers/)
- **Best for**: Mobile use (e.g., in vehicles) or home setups where you need loud, clear audio.
- **Connection**: Uses a 3.5mm audio jack, compatible with the BC125AT’s external speaker output.
- **Pros**: Durable, easy to mount with included hardware, good bass response for a communication speaker.
- **Cons**: Non-powered, so volume depends on the scanner’s output. Some users note it may not be loud enough in extremely noisy environments.[](https://singersroom.com/music-gear/best-external-cb-speakers/)
2. **Uniden BC7 Bearcat 7-Watt External Speaker**
- **Why it’s good**: This compact 7-watt speaker (3.5 x 3.3 x 2.4 inches) is a great choice for portability and space-constrained setups. It delivers clear, crisp audio and is compatible with the BC125AT via a 3.5mm jack. Its small size makes it ideal for backpacking or mobile use, and it’s durable enough for rugged environments. Users appreciate its value for money and performance with scanners.[](https://www.amazon.com/Uniden-BC7-Communications-Amplifying-Receivers/dp/B009PIRQ6E)[](https://www.scannermaster.com/Uniden_3_External_Speaker_BC7_p/10-531898.htm)
- **Best for**: Users who prioritize portability or need a speaker for both home and on-the-go use.
- **Connection**: 3.5mm audio jack, no external power required.
- **Pros**: Lightweight (8 oz), affordable, easy to install with included mounting bracket.
- **Cons**: Lower wattage means less volume compared to the BC20 or amplified speakers, which may be a limitation in noisy settings.
3. **Uniden BC15 Bearcat 15-Watt External Speaker**
- **Why it’s good**: A middle-ground option with a 15-watt output, the BC15 is a 4-inch non-amplified speaker that works well for desk setups or amateur radio applications. It’s compatible with the BC125AT and provides clear audio. However, some users report that the BC125AT’s internal speaker can be louder than the BC15 when connected via the headphone jack, likely due to impedance mismatch or low output power from the headphone jack (0.004W, 32 ohms).[](https://www.scannermaster.com/Uniden_4_External_Speaker_BC15_p/10-531824.htm)[](https://forums.radioreference.com/threads/external-speaker-suggestions.415166/)[](https://forums.radioreference.com/threads/external-speaker.382719/)
- **Best for**: Home or desk use in quieter environments.
- **Connection**: 3.5mm audio jack, no external power needed.
- **Pros**: Good clarity, affordable, durable design.
- **Cons**: May not be loud enough for mobile use or noisy environments. Not ideal for the BC125AT’s headphone jack due to low output power.
4. **Powered PC Speakers (Generic Alternative)**
- **Why it’s good**: Some users recommend powered PC speakers (e.g., Logitech or Creative models) for louder and clearer audio, especially when connected to the BC125AT’s headphone jack. These speakers have built-in amplifiers, which compensate for the scanner’s low headphone output (0.004W). They’re widely available and often provide adjustable volume and better sound quality.[](https://forums.radioreference.com/threads/external-speaker-suggestions.415166/)[](https://forums.radioreference.com/threads/external-speaker.382719/)
- **Best for**: Home setups or users needing maximum volume and flexibility.
- **Connection**: 3.5mm audio jack, requires external power (usually via USB or wall outlet).
- **Pros**: Louder than non-amplified speakers, adjustable volume, often inexpensive.
- **Cons**: Less rugged than Uniden’s Bearcat speakers, may not be ideal for mobile use due to power requirements.
### Key Considerations for the Uniden BC125AT
- **Audio Output Limitations**: The BC125AT’s internal speaker is 24 ohms with a maximum output of 0.36W, but its headphone jack is designed for 32-ohm headphones and outputs only 0.004W. This makes it challenging to drive non-amplified external speakers effectively through the headphone jack. For best results, use the external speaker jack (if available) or opt for amplified speakers.[](https://forums.radioreference.com/threads/external-speaker.382719/)
- **Impedance Matching**: The BC125AT’s audio output is optimized for 8-ohm speakers for the external speaker jack, but the headphone jack works better with higher-impedance devices (32 ohms). Mismatched impedance can result in low volume or poor audio quality.[](https://forums.radioreference.com/threads/external-speaker.382719/)[](https://forums.radioreference.com/threads/external-speaker-suggestions.415166/)
- **Amplified vs. Non-Amplified**: In noisy environments (e.g., vehicles), amplified speakers like the discontinued Uniden BC23A or powered PC speakers are recommended because they don’t rely on the scanner’s limited output. Non-amplified speakers (BC7, BC15, BC20) are better for quieter settings or when portability is key.[](https://forums.radioreference.com/threads/trying-to-figure-out-what-bearcat-speaker-is-the-best.462336/)[](https://forums.radioreference.com/threads/external-speaker-suggestions.415166/)
- **Connection Type**: Ensure the speaker uses a 3.5mm mono plug (not stereo) for proper compatibility with the BC125AT’s external speaker jack. Stereo plugs may cause connection issues.[](https://www.amazon.com/Uniden-BC20-Communications-Amplifying-Receivers/dp/B009TNABQ2)
- **Use Case**:
- **Mobile Use**: The BC20 or amplified PC speakers are better for overcoming road noise.
- **Home/Desk Use**: The BC7 or BC15 are sufficient for quieter environments, with the BC7 being more portable.
- **Portability**: The BC7’s compact size makes it ideal for travel or outdoor use.
### Top Recommendation
- **Uniden BC20 Bearcat 20-Watt External Speaker**: This is the best all-around choice for the BC125AT due to its balance of power, clarity, and durability. It’s suitable for both home and mobile use, and its 20-watt capacity provides a noticeable improvement over the scanner’s internal speaker. Ensure it’s connected to the external speaker jack (not the headphone jack) for optimal performance. If you need louder audio in very noisy environments, consider powered PC speakers with a built-in amplifier.[](https://www.amazon.com/Uniden-BC20-Communications-Amplifying-Receivers/dp/B009TNABQ2)[](https://bearcatwarehouse.com/products/20-watt-external-speaker)
### Tips for Best Performance
- **Use the External Speaker Jack**: The headphone jack’s low output (0.004W) is not ideal for driving external speakers, leading to low volume. The external speaker jack provides better power for non-amplified speakers.[](https://forums.radioreference.com/threads/external-speaker.382719/)
- **Check Impedance**: Stick to 8-ohm speakers for the external speaker jack to avoid volume issues.[](https://forums.radioreference.com/threads/external-speaker.382719/)
- **Test in Your Environment**: If using the speaker in a vehicle, test it to ensure it’s loud enough to overcome road noise. Amplified speakers may be necessary for high-noise settings.[](https://forums.radioreference.com/threads/external-speaker-suggestions.415166/)
- **Mounting**: Use the included mounting brackets for Uniden speakers to secure them in vehicles or on desks for stable operation.[](https://www.amazon.com/Uniden-BC7-Communications-Amplifying-Receivers/dp/B009PIRQ6E)
### Where to Buy
- **Amazon**: Offers the BC7, BC15, and BC20 with fast shipping. Check customer reviews for real-world feedback.[](https://www.amazon.com/Uniden-BC7-Communications-Amplifying-Receivers/dp/B009PIRQ6E)[](https://www.amazon.com/Uniden-BC20-Communications-Amplifying-Receivers/dp/B009TNABQ2)
- **ScannerMaster**: Specializes in scanner accessories and carries Uniden speakers like the BC7 and BC15.[](https://www.scannermaster.com/Uniden_4_External_Speaker_BC15_p/10-531824.htm)[](https://www.scannermaster.com/Uniden_3_External_Speaker_BC7_p/10-531898.htm)
- **BearcatWarehouse**: An independent Uniden reseller with a focus on scanner accessories.[](https://bearcatwarehouse.com/products/20-watt-external-speaker)[](https://bearcatwarehouse.com/collections/speakers)
- **eBay**: Good for finding deals on new or used Uniden speakers.[](https://www.ebay.com/b/Uniden-Radio-Speaker/48709/bn_319236)[](https://www.ebay.com/b/Uniden-Parts-Accessories/183503/bn_56940255)
If you’re in a noisy environment or need maximum volume, powered PC speakers may be a better alternative due to the BC125AT’s limited headphone jack output. For most users, the Uniden BC20 strikes the best balance of performance and compatibility.
firecaptdave
Watch Duty Reporter
Prescott AZ
I have a small Bluetooth transmitter that plugs into the earphone jack, and use either my ear buds or an Anker rechargeable portable speaker when I want more clarity.
Which BT transmitter are you using? I tried one and got too much stray RF. TIA
brcoz
Florence, AZ
Back in 2023 I got this one from Amazon. It is unavailable now. It worked very well in the car on trips and in Las Vegas in the Casino's.
I just used one earbud.
Bluetooth Transmitter Receiver, Low Latency 4-in-1 Wireless Bluetooth 5.0 Audio AUX Adapter with Display Screen for Car/Home Stereo System, TV,PC​
Ubbe
Stockholm, Sweden
It seems to have a 150 ohm resistor to its output jack for the positive signal and 10 ohm for the negative and are a floating signal, no ground are used and the 10 ohm are a protective resistor if you accidentally short circuit it to ground. So no speaker can be used without going inside the scanner and short circuit those resistors, the only two chip resistors at the connector, as the amplifier can produce almost 2 watt with some distorsion and have built in protection.
Many Bluetooth transmitters are made for music with a continuos signal and when used with a scanner that can be quiet for a longer time between activity the BT can go into sleep mode and will take a second or two to wake up and start to transmit and the BT receiver needs a while to react and sync again and you lose the first words.
/Ubbe
