SDS100/SDS200: External USB drive problem
crippledchicken
Butler County MO
There shouldn't be, Windows detects what the device is when it is connected and uses whatever driver is appropriate.
nessnet
What month is it?
If I have USB issues, first I disconnect the device(s)
Then go into Device manager, make sure to check the hidden devices box (view/show hidden devices)
Right click on the ones in question.
Uninstall device.
Try again - Windows will P and P it and this almost always fixes it, unless there is an actual hardware fail (or I suppose bad driver)
If driver, choose the update driver to see if that'll work.
Ubbe
Stockholm, Sweden
So you're asserting that if I plug "device A" into "USB 1", and plug "device B" into "USB 2", then disconnect both devices and plug "device B" into "USB 1" there will be a device-driver conflict?
Sometimes devices are not addressing themselves properly to Windows, or if it Windows that have a problem, so that drivers get interchanged and needs it to be reinstalled, and sometimes all drivers for that port needs to be cleared and when you insert a device it will install that driver again, a driver that already have been installed in windows and will pull that from its driver library.
/Ubbe
