Danny37
442...please elaborate. I believe you, but haven't found a way to dip into the ham band. I indeed see that the F7010 is built on the same chassis and probably share many hardware components.
The radio already has a wideband license (which I have tested) so I'm good as far as 25 khz bandwidth for analog.
Are you literally just entering the hammy stuff with no other intervention? Does the cloning software give a warning about model number etc? On my Kenwood upper split radios I get the warning prompt about frequencies being out of range, but I just hit ENTER again and they are accepted.
I can enter 44x.0 frequencies and dump them into the radio. However after re-boot and power up when I switch to those channels I get a rapid red/green flash on the led status light. Icom lists this status pattern as "programming error". No tx or rx. Then I switch to any of my 450 mhz and above channels and it acts as normal.
Keep in mind I have easily loaded out of band UHF ham stuff in older legacy Icom UHF gear with no issue.
Have you had any luck with this? I'm trying to do the same thing as you but in the F52D and I'm getting same flashing error. I gave up awhile back but happened to come across your thread.
