F3001 Direct Clone (via OPC-474 Cable) Anyone Done It?
DavidTag
Seattle, WA
I can clone my F3-2 radios directly (radio-to-radio) via the OPC-474 cable and I'm supposed to be able to do the same thing with my F3001 radios (based on the cloning software help file.) But I can't make it work. Has anyone tried it?
gmrsoutlet
Oswego, IL
Don't think that this can be done on this radio.
Seems that the radios with advanced features such as the F4001 (MDC, with stun/kill and selective calling) they don't have the Radio to Radio Clone option.
Mostly because with these radios it is very possible to have a radio that has a unique personality that would cause issues on a radio system if it was copied exactly and put into use on a system that requires unique personalities.
Also with advanced feature radios like this - where a personality that is unique it allows for dealer protection on systems where air time might be used with some of the mentioned features.
DavidTag
Seattle, WA
The help file within the CS-F3000 programming software (admittedly not an infallible information source) says the following:
If "Inhibit" is selected, data cloning operation between transceivers is also inhibited.
The procedure for the transceiver-to-transceiver cloning:
1. Turn the transceivers OFF.
2. Connect the OPC-474 CLONING CABLE to the [SP] jacks of the master transceiver and the sub transceiver.
The master transceiver is used to send data to the sub transceiver.
3. While pushing [Upper] and [Lower], turn the master transceiver ON to enter the cloning mode.
Turn the sub transceiver ON normally.
4. Push [PTT] on the master transceiver to transfer data to the sub transceiver.
5. After cloning is completed, turn the both transceivers OFF. And then turn the transceivers ON again to exit the cloning mode.
My F3 radios have a display that helpfully says "CLonE" when it's in clone-mode. No display on the F3001 so no feedback.
