F70D programming issue
Not sure if its me or the radio on this one so here goes the problem:
I have 5 IC-F70DS (DS Digital Partial Keypad hence the S model) All 5 radios are flashed with the same firmware v2.9 and using the same software version v2.2. All 5 radio's are being programmed the same way minus the Name Text area. Channels, Zones, Banks, 2-Tone, P25 ect are all the exact same. On one radio, Just one I get a different question when I write to the radio. "MDC 1200 will not be available while you write to transceiver, Are you sure?" First off, I am not using any MDC1200 what so ever. Next, when I write to this radio it accepts the programming minus one key issue. No Digital. It won't transmit or receive P25 at all. The other 4 do it flawlessly.
The radio case with the battery off shows the EXACT same model as the other 4. All these radios were purchased together as Part of a DHS Grant. All Digital is with NAC code and in NFM. All 5 are receiving two tone pages from the new paging system but this one oddy will not Xmit P25 it clone Writes fine.
What might be the obvious answer to this dumb question? The Distributor screwed up and sent a Hybrid without a P25 board in it?
I need to know something to tell My Emergency Manager tomorrow that would account for this issue - ANY help is appreciated
Thanks - In Advance.
grumps96
Massachusetts
I don't know if this is the answer, but I looked at the software and there is a drop down on top that says Model, You should check and see that the same model number is selected for the one that does not work, as is selected for the ones that do. I do know that any changes in the selection, changes the way the rdio will operate.
Thanks for the reply.
These all use LMR (P25 Conventional) and the other 4 radio's program fine. I suspect this radio is missing a Digital card or is entirely the wrong radio. Mismarked case? I dunno. Thanks again!
RADIOGUY2002
Chicago Burbs
i SUSPECT
I suspect your right, if the other four play nice. I would assume it save to say that the one was not setup with that capability of the board is bad. Either way the P25 is not capabale in that radio. They all say the same firmware number so my guess is the board is missing as suggested or went bad as the settings are identical unless a box is checked that was missed. Usually when doinng fleet I set up one software file and duplicate it over and change the mdc1200 number at the intial programming. That way they are all identical except for the designator. Call the suppiler and see what the deal is, maybe you missed somthing or maybe they missed somthing when selling it.
And such was the case .... Freaking Hybrids! Got a new one on order - thanks again.
DWVFD29
Belpre, Ohio
F70DS Issue No P25
I have a IC-F70DS when I write to this radio it accepts the programming now It won't transmit or receive P25 at all. Had Worked For The Last 3 Years When i Purchased This Radio. Just Am Confused What Could The Problem
Any Assistance Would Be Appreciated
