I emailed RS to ask them about the rebanding. Here are the emails
that I got back. I don't know if it will help anybody, but here it
is!!!!
Thank you for the e-mail,
Unfortunately, the Pro-95 will not be able to be rebanded. The Pro-
96,
97 and 2096 will.
To better assist you with future questions, please respond to this
original email with the REPLY option.
Thank you,
Lori
RadioShack Product Support Center
LN/kk
http://www.radioshack.com
Here is another email from Radio Shack
The PRO-96 and PRO-2096 includes a
"custom table" range configuration that allows up to six table
configurations to be defined for both Motorola and P25 trunked radio
systems. A custom table range configuration consists of a base
frequency
(i.e., "Base = Channel 1"), a step size for the range (i.e., "Channel
N
= Base + N * Step") and an offset value (i.e., "Offset the channel
number by this value").
In the current Motorola channel plan for the 800 MHz band, there are
four or five range definitions that allow Motorola radios to access
every frequency in the 800 MHz band. We know what these ranges are,
and
have hard coded them into the PRO-96 and PRO-2096, so the radios
behave
exactly like Motorola radios when trunking the 800 MHz band.
In testing the six custom ranges, we were able to successfully
trunktrack the 800 MHz Motorola systems by turning the custom range
feature on and hand programming the 4 or 5 ranges that Motorola uses
to
define the 800 MHz band.
So...
Once the new Motorola bandplan for the reconfigured 800 MHz band is
known, it should be a very simple matter indeed to come up with the
correct base, step and offset values to make the PRO-96 and PRO-2096
track the 800 MHz band correctly on systems that have been rebanded.
With the exception of the actual channel tables themselves. We are
aware
of what Motorola plans to do with the their 800 MHz channel mapping,
and
are very confident that the PRO-96 and the PRO-2096 will be able
handle
800 MHz rebanding just fine.
Thank you,
Lori
LN/kk
