FCI - Memphis
Gatorman
Memphis, TN
Has anyone attempted to listen to the Federal Correctional Institute system in Memphis? I checked all the freqs in the database and couldn't locate a CC. I swept the band and found 408.250. Same System ID as listed in the DB. No traffic so far. Any ideas about this system?????????
Listening to it as a UHF system vs. P25 with 396T. If I don't hear anything soon, I will try it as a P25 system.
wmbio
Cumberland, Md
Fci
Gatorman,
The FCI in Cumberland, Md went digital and looks like a splinter UHF trunk. They are using the same control channel, 408.250, system ID is correct also but I cannot get it to track the splinter voice channels.
wmbio
Gatorman
Memphis, TN
I have tried about everything I can think of this morning with this system but can't hear a thing. I do get TG IDs if I hold the radio on the CC but they won't track. Also getting TWO CCs with same SID. What the heck is that?????????
Thanks for the reply.
wmbio
Cumberland, Md
Fci
2 sid's are not uncommon in trunking, the radios will respond to the channel they hear and can decode best. Read up on UHF trunking, I am doing the same, the channels do not follow the normal scan sequence, you said you were in Memphis?. Put all of the active channels lised here for the FCI in a bank and see if it will scan.
Wmbio
C&P of the RR data base
System Name: Federal Correctional Institution Memphis
County: Shelby
System Type: Motorola Type II SmartZone
System Voice: APCO-25 Common Air Interface Exclusive
Sysid: 9106
CT: 138.46
Last Updated: 09-25-2005 11:22 Changed Site-001
Hits: 392
System Frequencies
Red* are Primary Control Channels, Blue* are alternate control channels
Site Description Freqs
001 Primary 406.00000 407.52500 407.92500 408.25000* 409.21250* 410.40000* 411.12500
