Nearly 40 years later and they are still using the same not ready for prime time technology. When I worked NYCEMS 911 in the early 80's the NYPD radio shop built what I call a subway extender for the 109 pct frequency at Main and Roosevelt. It was nothing more than a big yagi aimed at the nearest transmitter with 7/8 coax run underground to believe or not a RX amplifier in a 1900 electrical box with a unity whip mounted on it. On the opposite platform was a unity whip on the 1900 box the RX amp inside with 7/8 coax run to topside omni antenna.
It would make more sense to just run a IP line to a repeater station with leaky cable, and I know they have IP since all the signs are IP.
One of the requirements for these relays is that they cannot transmit any power that would interfere with the above ground radio.
GCT has a very large infrastructure of radio equipment for FDNY, NYPD, FDNYEMS, MTAPD plus the RR freqs covering all areas of the terminal, building and tracks. Unfortunately IMO they are doing the same thing just with very expensive in band simplex repeating, and while I was still there we had some outside antennas stolen.
During at multi-agency drill in the Park Ave tunnel one night FDNY had some neat equipment that relayed the portables to above ground command vehicle using fiber optic cabling. For MNRR Fire Brigade I had built a cross band repeater in a pelican case with battery which I located at the bottom of the escape stairs that took our VHF Fire channel and sent it upstairs on a UHF interop and it worked great.
Besides radio equipment FDNY had a battery powered trolly that came in 3 pieces with a stretcher that could run on the rails, and it was also the first time I saw re-breather packs being used.
