FDNY Fireground Tone
Salmatt30
I currently own a Motorola XTS 3000 programmed to the FDNY Frequencies including Tac1 (Fireground) I figured it would sound the same but it doesn’t... Anyone know how I can make it have the same tone as them? Something to do with the chip or something can anyone help me make it exact?
62Truck
Ordinary Subscriber
Ø
They use TPS signalling. Its basically analog voice with P25 data either before or after transmission. In FDNY's case they use it after transmission. All this does is allow them to give the radio a longer radio ID number and still have analog audio.
The XTS3000 is not capable of this.
Salmatt30
What radio is capable? I’ve seen FDNY use XTS 5000 and 3500 would those work?
Salmatt30
My radio is a Motorola XTS 3000 Modell II UHF 450-520 MHz P25 S-split two way. Are you sure it’s not capable
62Truck
Ordinary Subscriber
Ø
FDNY Fire uses XTS3500's and APX8000's. EMS uses the 5000's. The Astro 25 series are capable depending on if it was flashed for that option.
Yea..... I'm pretty sure.
Salmatt30
So if I get the 3500 how would I go about doing and setting this setting or signal?
Salmatt30
Motorola XTS 3000 Flash Code?
Flashcode 100004-000000-4
Then on the back I have a Mfg Code if that is anything 1000010000007
N1XDS
ÆS Ø
Could I force a flash code into the radio?
You can but you'll have the depot software and put in the flashcode your wanting to use then program it to the radio and then reprogram your radio in the CPS.
IAmSixNine
Dallas, TX
The depot software is not legitimate software. Its not for sale. Its not really supposed to be mentioned.
The legitimate way to modify the flashcode is to get the unit to an authorized motorola dealer or send a unit to motorola.
Problem is i believe the 3000 are EOL, enf of life. So you might not be able to legitimately get a new flash code in there.
Salmatt30
The reason I want to do this is so that I can have a TPS at the end of a transmission for the FDNY Fireground and so far no luck
mikewazowski
Forums Manager
Oot and Aboot
Sorry but we don't discuss Depot or adding features that you haven't paid for on this site.
It's all kind of moot anyways since your xts3000 won't support tps.
Will001
SC
All I’m going to say is, there is a tool called the “FDB tool”. Just go find it, and you’ll see why I mentioned it.
FFPM571
The Mid South
then again if your not a Member of FDNY you should not be transmitting on their fireground.. If you need to be on their frequencies then you should have a legitimate radio that is provided by them
N4KVE
PALM BEACH, FLORIDA
Well it wasn’t created by the same Russian hackers who “threw the election”. It was created by the engineers at Moto for use only in the plant. It was never supposed to leave the building, but it did. The public was never supposed to get their hands on it, but they did. But it was developed by Moto, so it is legitimate.
Salmatt30
It's all kind of moot anyways since your xts3[emoji646][emoji646][emoji646] won't support tps.
I found a 3500R so if its a 3500 it would allow TPS?
