If I wanted to set my scanner to search between two freqs that encompass the Fed band, what would they be? I know it's like 160Mhz or something like that..
rescue161 said:The ones that we used were always from 136-144 & 148-151. I know that some agencies have a small segment up in the 160/170 range, but we never used those.
wayne_h said:173.0000 - 173.4000 can and will be assigned for Film and Water departments. Just a heads up. Often any telemetry heard in this range is a local gov water dept.
benrussellpa said:136-144 and 148-151 would be military land mobile (FM) or aircraft ops (AM).
Federal agencies primarily operate in the 162-174 VHF range. As already mentioned, fed agencies (i.e. DEA, USPS law enforcement, etc.) also use a lot of UHF.
ETA: my range was off. It starts at 173.2000, so that jives with your list.Mick said:173.0375 “Command” “Santiago Comm” w/170.4125/170.6875/417.30
173.0500 167.9/DES FBI
173.0750 LoJack
173.1250 167.9 FBI L.A.
173.1500 P25 encoded FBI
173.1750 P25 encoded FBI
173.2500 146.2 L.A. Water & Power
173.3000 173.8 San Gabriel Co. Water District
173.3000 179.9 Lake Arrowhead Comm. Services District
173.3750 85.4 Disneyland Camermen
406-420brandon said:The real good stuff is between 167-168 MHz
Also don't forget the UHF fed band. I mostly search 417-420 MHz but you could extend it from 413 or so.
BaLa said:406-420
380-386? not sure on how high that goes..
