My first [and most obvious] error was speculating that these were G20 specific. One has to keep in mind I'm not typically an enthusiast of the Federal spectrum. One also has to keep in mind that I questioned [i.e. ?] whether these were related to the G20 summit.
I had originally made that speculation based upon the fact that I'm so close to Pittsburgh, significantly far from any other major metro area where I would likely be hearing such strong signals, and the G20 summit was coming up where one could anticipate hearing increased Federal activity. I didn't take into account that the interoperability issues that would make significant federal repeater use nonfeasible for the event.
Since for the past week I have not heard any traffic on any of the frequencies I originally posted [except an occasional transmission on a single frequency], I have no way of going back to attempt to vet them.
I'm going to assume the two you primarily dispute are:
153.2225 NAC 167 P25
157.6425 NAC 167 P25
If this is correct, I'm within you on that. I can't say I've heard 153.2225 more than the single day that I originally heard it (and probably only heard it once or twice in short succession). At that time I was hearing a lot of frequencies broadcasting the audio, and so it is possible that it was an image from another frequency. 153.2225 is in my scanner, and I'll certainly attempt to determine if traffic on it is legit when I hear it again. In the meantime, scratch it from the list and chalk it up to a figment of my [or my scanners'] imagination if you wish.
As for 157.6425, I am aware of the fact that it is in spectrum normally used by taxis, etc. I know this raises huge doubt. However, prior to me ever noting transmissions on this frequency that were occurring simultaneously on a ton of other frequencies, I was hearing transmissions on this frequency only (and then alter on, on a couple 150.xxxx frequencies).
See:
150.5625 / 157.6425 (NAC 167) - P25 (clear and encrypted)
So I've been monitoring 157.6425 for much longer than any others that I listed and am at least convinced for my own benefit that it is a legit transmitter output since many of the transmissions I was hearing on it in the beginning were not to be heard anywhere else on VHF. I was hearing various players staking out a bar in Pittsburgh on this one.
You've at least indicated that you believe some of the 160 Mhz frequencies are accurate by virtue of you verifying them yourself or somebody else having verified them in the past. Is that correct? If so, exactly what frequencies out of those I have listed have you recently monitored and can verify that indeed traffic was heard on them?
So, if you're only disputing the 153 Mhz frequency and the 157 Mhz frequency, I have explained how I believe the 157 freq is legit but the 153 Mhz could certainly be an image or intermod (although, i'd tend to think an image since I was getting decodable P25 on it and wouldn't expect to be able to have a solid P25 signal from two external transmitters mixed together).
for the 150 Mhz frequencies, i'm confident of 150.5625. It's one of the handful of frequencies that I originally listed which I also programmed into a handheld using the stock antenna and still could identify a clear P25 signal (it was an analog scanner, but nevertheless I was confident that the signal was pure). I discussed 150.5625 on these forums, posted in March on my site, and maybe even tossed it up for review over at the TRAMAlist.
Contrary to what you may think, I don't have a problem collaborating. I do have a problem with being one of one who has reported these findings
recently in the Pittsburgh listening area and then not having gotten anybody else to chime in with any sort of clarification / verification - instead all I get are people who apparently know significantly more than me suggesting that many of my findings are merely images.
I tossed them out there hoping that somebody else could verify specific frequencies... but nobody has come out and said that they heard anything on any of those frequencies directly in the timeframe when I was hearing all of it. Some posted that from other records they have from the past, or from information they see on other sites, certain frequencies are in use by agency X in city Y. But nobody has attempted to "collaborate" with me -- They've only attempted to negate my findings. If somebody truly wants to "collaborate", then somebody has to plug them all in and then post when they hear something on one or more of them to provide verification of those frequencies that can be verified.
Mike
