Federal NAC codes
RTrue
Covington, KY
Nac decoders
I tried both the audio and discriminator.With both, after I select the sound card, it just sets there with three big zeros on it, either polarity.
Randy W4RTT
Audiodave1
Chadds Ford, PA
did you select the sound card source on the KnacK display? Mine is compacted to a point where I cannot see there are multiple selections.
RTrue
Covington, KY
knack
I have only one choice; default input. After I select that, the program shows it's running.
Randy W4RTT
ericcarlson
Houston, Texas
With kNACk, I found that I had to play with with the input volume levels to get it to decode properly (otherwise I got nothing). Once I got that figured out it works reliably.
JASII
Memory Capacity
Federal NAC Codes
I have used it via discriminator tap on a Yaesu FT-8800 and that was my experience as well. If the input volume level was too low, I had zeros in the display.
davynavy
North Richland Hills TX
DHS-FPS NAC Codes
I have the following:
DFW 731
Houston 798
New Orleans 742
Baton Rouge 753
El Paso 709
San Antonio 715
OKC 764
Little Rock 721
Austin 776
Albquerque 787
Region Main 201
T/A 293
WayneH
Forums Veteran
Super Moderator
Your master site
going to sound like a stupid question but how do you find the NAC codes?
With an appropriate scanner such as a GRE500/600, RadioShack 106, Uniden 396/996XT, software such as kNACk, or professional two-way test equipment such as a Motorola or IFR service monitor.
h20oni
NAC to CTCSS
Here's something I found on the subject...
From the TG-001 P25 Radio Systems Training Guide
Daniels Electronics - Home Page
Chapter 3: P25 Practical Applications 27
CTCSS to NAC Conversion
Early TIA documents specifi ed a formula for converting analog CTCSS tones and DCS codes to specific NAC codes. Those documents have since been removed and the selection of NAC codes has been left
to the user. Some government agencies have defi ned a conversion table for their own use for translating CTCSS to NAC codes (eg. State of California and others).
Shown below is the early TIA conversion table from CTCSS to NAC codes. These codes were determined by taking the CTCSS frequency and multiplying it by ten, then converting the integer result
to a hexadecimal number.
CTCSS to NAC code conversion chart
CTCSS NAC Code
67.0 Hz $29E
69.3 Hz $2B5
71.9 Hz $2CF
74.4 Hz $2E8
77.0 Hz $302
79.7 Hz $31D
82.5 Hz $339
85.4 Hz $356
88.5 Hz $375
91.5 Hz $393
94.8 Hz $3B4
97.4 Hz $3CE
100.0 Hz $3E8
103.5 Hz $40B
107.2 Hz $430
110.9 Hz $455
114.8 Hz $47C
118.8 Hz $4A4
123.0 Hz $4CE
127.3 Hz $4F9
131.8 Hz $526
CTCSS NAC Code
136.5 Hz $555
141.3 Hz $585
146.2 Hz $5B6
151.4 Hz $5EA
156.7 Hz $61F
162.2 Hz $656
167.9 Hz $68F
173.8 Hz $6CA
179.9 Hz $707
186.2 Hz $746
192.8 Hz $788
203.5 Hz $7F3
206.5 Hz $811
210.7 Hz $83B
218.1 Hz $885
225.7 Hz $8D1
229.1 Hz $8F3
233.6 Hz $920
241.8 Hz $972
250.3 Hz $9C7
