National Incident Radio Support Cache Scanner Frequencies and Radio Frequency Reference - NIRSC
National Interagency Fire Center Scanner Frequencies and Radio Frequency Reference - NIFC
I think these pages can be merged. AFAIK there is just 1 office in Boise that is responsible for all of these radio channels. They ship out the radio kits to forest fires, major disasters, and probably the big security events.
Federal wildfires - a listening guide
Initial dispatch and response will be on the Forest Net (USFS), Fire Net, Refuge Net (FWS), District Net (BLM or NPS), Park Net (NPS) or Agency Net (BIA). These nets are typically repeaterized and offer wide area coverage between field units and dispatchers.
The first arriving units will probably switch to a Tac Net or SOA Net (Scene of Action - BLM). This will usually be a simplex channel used by portables and mobiles. There is usually no direct contact with dispatchers available on these channels. (Tac Nets listed above are for USFS units typically). BLM has their own channels for SOA. BIA, FWS, and NPS sometimes use direct channels or separate Tac nets.
Also used are - Crew Nets for handcrews - Air to Ground - Air to Air FM - Air to Air FM ("Air Tactics"). (these are listed above)
If the fire grows in size and additional units are dispatched to the scene, then portable repeaters will be deployed. The portable repeaters will operate on the NIFC Command channels listed above.
If a fire camp is established, the Logistics channels will be used at the fire camp.
Sometimes UHF channels are used to link Command repeaters together. UHF channels are also used sometimes to link the fire camp to AM base stations to communicate with aircraft.
123.975 is commonly used at air tanker bases.
168.55 is used by smokejumpers.
(The NIFC Air to Air channels that are listed might be considered spare channels).
Sometimes AM channels are used for air to air communications. it depends on local needs.
What am I forgetting?
