Feed problems
N0TDL
Marshfield, MO
Im having a problem with my feeds , they seem to time out and then just buffer... , I listen to my feeds via my laptop while the feeds are threw my desktop , if there'ss silence for a while sure enough i have to restart my web player
Is anyone else having this problem
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
I haven't noticed any problems with my feed. I have your Lawrence Co Sheriff and Fire feed up now and I"ll listen to it for a while to see if it stops on me.
I'm guessing it is likely a problem on your end on your internal network.
Either:
1. You are saturating inbound or outbound bandwidth on your connection or your internet connection is intermittently bouncing
OR
2. You don't have a good wireless connection.
Sure, it could be RR - but I haven't seen any sign of that yet. How long do you hvae to listen before you experience that problem [so I'll know how long I have to listen to your feed before determining if there is a problem wtih teh feed].
If it were an RR problem, then there would be hundreds or more listeners experiencing the same thing.
mike
mtindor
OH/WV DB Admin
I do have a suggestion for the Lawrence Co Sheriff and Fire feed - you should consider turning up the audio a bit. I'm listening on my laptop speakers with the player volume and my master volume up all the way and having difficulties hearing a lot of what is said because the volume is low.
Hmm, are you running a stereo feed with fire on one side and sheriff on the other? If so, both are a bit low.
Mike
N0TDL
Marshfield, MO
not too sure on how long before it dose that , and i have turned the volume up as well , thanks Mike for the quick reply
mtindor
OH/WV DB Admin
The side you were listening to the NWS on _may_ be a _tad_ too loud now... or it may be just right. I heard you testing it and obviously you were monitoring it because it was clipping for a minute and then you turned it back down. Definitely sounds good now. Perhaps perfect, perhaps just a tad too loud. I can't really tell yet but I'll keep listening.
Mike
mtindor
OH/WV DB Admin
I think its significantly better now. As long as it isnt' clipping audio, it's better to be too loud vs too low. Anybody can turn it down in their player if it's too loud for them.
So as far as my ears go, they are hearing things very nicely now.
Mike
N0TDL
Marshfield, MO
Well thinks again and sorry for your temp damage to your ears LOL , it will be nice when we the volume check option back . Im still monitoring and waiting for it to time out . i guess if im away from my my laptop mayby the screen saver settings is shutting the feed down or the laptop is going to sleep
N0TDL
Marshfield, MO
allright , I have had to restart my web player now 4 times since i posted this thread , Mike has it silenced on you or did you experience any trouble ?
I was also monitoring a GA feed at the same time
the GA feed never timed out on me
mtindor
OH/WV DB Admin
No, it didn't time out on me, but i stopped listening about 10 minutes ago (while I was programming my own scanner and becoming confused listening to your feed at the same time rofl).
But it didnt' time out at all during the time I listened.
Mike
KAA951
Kansas
I was having the same problem and just switched to Scannercast instead of the RR software.
Ham Radio Station K1PGV
This is freeware and is listed on the RR Wiki for streaming audio. It was easy to set up and I have been running for hours now without interruption.
KAA951
Kansas
Yes, it works with any scanner. Just select the audio only option.
