Feed
AC0RV
Park Hills, MO
Ok now that I have the feed. When I do update the scanner to next 396xt and so forth. I know I can have UID lookup. But where does the talk group txt is listed and if it does reside with the radio will it show when click on the file selection in the options portion of the program ?
I am trying to learn and may over looked that in the helps.
Thanks for being so patience with me while I learn new things.
Happy Scanning.
W8RMH
Feed Provider Since 2012
You will only be able to stream the ID number itself. You will not be able to stream the radio ID description tag.
If you program in the radio ID description your scanner will receive, and stream, every transmission from that radio, regardless of which TG is being used, even those transmissions prohibited by the Feed Providers Terms of Service, such as tactical channels, car to car, SWAT, phone patches, etc.
Unfortunately there is no way to prevent this from happening.
I feature radio IDs on my feed and was unable to do what you want to do. I do include an "ID Format Plan" in my feed notes which allows my listeners to decipher the radio ID number. Depending on your system's format plan you may not even be able to do that.
