Feeds not playing in Winamp the last few days
apollosfyre
Sonora, CA
I use Winamp as my feed player, as it allows multiple players, assigned to different outputs. It has been excellent for many years, but the last couple of days, none of Broadcastify's feeds will play in any instance of Winamp, in any PC I try to use. Has something changed, or is this just an issue which will be fixed soon? If Winamp is no longer to be supported, is there another player that will do the same job of multiple instances, and control over the outputs? Any help would be appreciated.
Whiskey3JMC
Resident Numbskull
Simulcastylvania, TE
I use VLC, it's lightweight and ideal for multiple instances. Are you running the latest version of Winamp on the PCs? Not sure what you mean by "control over the outputs". Are you referring to the ability to create a "playlist" with the different feeds?
baj76
Uniden fanboy
Does VLC show Alpha Tags like winamp does?
apollosfyre
Sonora, CA
I use an 8 channel audio card that allows me to record each player, and Winamp has the ability to configure each player to it's own output channel 1 thru 8. Does VLC have such a feature?
ibagli
Ohio
I think the issue is that the m3u files now use HTTPS URLs. I upgraded to Winamp 5.8 and got them working again.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
We have been gradually moving more and more to https for everything. Sounds like a latest upgrade to Winamp resolves the issue...
Progline
Central Washington State
Are there settings in 5.8 that need to be modified? I downloaded & installed 5.8 and still can't connect to the relay.broadcastify server....it just eventually times out.
Progline
I got it to work, you have to manually press the PLAY button on Winamp when it opens a new session -it looks like its trying to automatically start, but it isn't.
baj76
Uniden fanboy
when i manually press the PLAY button on Winamp , it still doesn't work for me
jasonpeoria911
Peoria, IL
Has their been any fix for this yet? I read the thread from February but that didn't fix anything. Winamp has latest update on my computer. I don't mind using another program to listen but winamp is the only one with text tags.
a417
The only way I've gotten the feeds to play in WinAmp is to use the play URL drop down and manually type in the feed URL using the following format: http://username:password@audio.broadcastify.com/feedid.mp3 (radio reference user name, password & feed ID). Like others here, upgrading to WinAmp 5.8 does "not" resolve the issue (Win 10).
@blantonl mentioned the gradual transition to HTTPS, yet your posted link is http. Was that intentional?
(edit - oof, month old post. sorry)
wgbecks
NE Wisconsin
Winamp 5.8 does not support https. However, you can bookmark the feed then edit the URL to remove the "s" from https and the stream will open and play normally.
Chronic
I cant get this to work . Is the web player the only Option left ?
