FIPS codes for ontario
martyjess
Anyone in northern ontario using FIPS codes.
Do we have big enough storms to even program this in our scanners??
I programed the FIPS codes into my BC250D, will I ever hear something??
randyf
Strange days indeed
campbellford ontario canada
when the winter storms come you should get warnings , down south through the summer thunderstorms fips was very active this season
gary123
the only problem I have found is that they tend to send the fips out only once, I f you are like me I dont have a dedicated reciever but do dial over to weather radio when conditions look bad. I contacted Enviorment Canada about this and was told that they do not wish top create panic by issuing more than one precautionary warning.
Im sure that when I get stuck in white out conditions I will apreciate this policy.
randyf
Strange days indeed
i use my scanner for weather warnings but it limits the radio to that use only i wish fips could operate in the back ground like close call do not disturb
mikewazowski
Forums Manager
Oot and Aboot
So, because you don't have a dedicated receiver, the rest of us would have to put up with multiple alerts going out constantly for the same warning?
That would cause people to start ignoring the repetitive alerts and miss an upgraded warning.
Check this link out:
Weather Radios Emergency Alert All Hazard Radio
With radios going so cheaply these days, if you get stuck in a whiteout, it's your own fault.
gary123
Actually updated warnings would be great, infact I find myself agreeing with you on multiple alerts about the exact same thing. Perhaps Enviorment Canada can put a bit more effort into updating alert info as it becomes available. I was just venting a bit about the snotty attitude I recieved when I contacted Enviorment Canada about the FIPS system and criteria used to decide an alert.
BTW I never travel anywhere without the proper equipment and materials ( I even carry a mini inflatable raft)
vabiro
Toronto, Ontario
On a related issue, does anyone make a receiver that will do weather alerts on conventional broadcast FM stations (88-108MHz)?
For example, the WXR station in Parry Sound is on 88.9, and as a result none of the radios I have found can be set-up to do an alert if there is a weather warning in the area.
Short of listening all the time, is there an option?
Victor
martyjess
fips codes, canada clc codes
Timmins, little abitibi, kesagami lake cochrane, iroquois falls fips codes: 049500
049520
049510
martyjess
ontario fips codes
Just go to google and type CLC codes for ontario canada and you will find it all there.
CLC is the canadian word I guess for FIPS.
