Fire apparatus numbering in the state
mws72
Quad-Cities (IA-IL) USA
I have looking for a list of standard fire apparatus numbering in most counties. Usually the Cities are straight forward. Engine 2 or Truck 4. Most the ambulances in Eastern Iowa usually goes by county number followed by the letter A with a unit number. Some counties like Clinton Co. uses a 5x series in the county listing. For example Genesis DeWitt has units 1851/52/53. While Cedar County uses 16Axx. Of course Scott County Medic used Medic xx.
Guldnerk
Benton County, IA
Following, I have some for my County and it helps with the UIDs for the SARA network. I agree even here they go by the
County Number - A - ##
Guldnerk
Benton County, IA
Below is what I have for my area
CountyAmbulanceDescriptionCountyFire TruckDescription
06 Benton60Belle Plaine Ambulance57 Linn344Palo
06 Benton6157 Linn345Palo
06 Benton62North Benton Ambulance57 Linn349Palo
06 Benton63Atkins Ambulance06 Benton630Atkins
06 Benton6406 Benton631Atkins Fire Truck 631
06 Benton6506 Benton632Atkins Fire Truck 632
06 Benton66Newhall Ambulance06 Benton633Atkins
06 Benton651Shellsburg Ambulance06 Benton634Atkins
57 Linn30Area Ambulance 3006 Benton640Urbana Fire Truck 640
57 Linn31Area Ambulance 3106 Benton644Urbana Fire Truck 644
57 Linn33Area Ambulance 3306 Benton645
57 Linn34Area Ambulance 3406 Benton650Shellsburg
57 Linn35Area Ambulance 3506 Benton654Shellsburg
57 Linn36Area Ambulance 3606 Benton658Shellsburg
57 Linn37Area Ambulance 3706 Benton659Shellsburg
57 Linn41Area Ambulance 4106 Benton701Vinton
57 Linn42Area Ambulance 4206 Benton703Vinton
57 Linn43Area Ambulance 4306 Benton705Vinton
57 Linn46Center Point06 Benton707Vinton
57 Linn85Hiawatha Ambulance06 Benton711Vinton
57 Linn86Hiawatha Ambulance06 Benton715Vinton Fire Truck 715
57 Linn8706 Benton719Vinton
57 Linn300Area Ambulance 30006 Benton724Newhall Fire
86 Tama332Tama County Ambulance 33206 Benton729Newhall Fire
06 Benton650BShellsburg Fire Truck 650B
48 Iowa2Amana Fire Engine 2
52 Johnson1Johnson County Engine 1
52 Johnson2Johnson County Engine 2
52 Johnson3Johnson County Engine 3
52 Johnson4Johnson County Engine 4
57 Linn1Hiawatha Fire Truck 1
57 Linn2Cedar Rapids Fire Engine 2
57 Linn3Cedar Rapids Fire Engine 3
57 Linn4Cedar Rapids Fire Engine 4
57 Linn5Cedar Rapids Fire Engine 5
57 Linn6Cedar Rapids Fire Engine 6
57 Linn7Cedar Rapids Fire Engine 7
57 Linn8Cedar Rapids Fire Engine 8
57 Linn9Cedar Rapids Fire Engine 9
57 Linn12Cedar Rapids Fire Engine 12
57 Linn91Marion Fire Engine 91
57 Linn92Marion Fire Engine 92
57 Linn93Marion Fire Engine 93
57 Linn94Marion Fire Engine 94
57 Linn346Palo Fire Truck 346
57 Linn347Palo Fire Truck 347
57 Linn348Palo Fire Truck 348
57 Linn354Fairfax Fire Truck 354
06 Benton654Shellsburg Fire Engine 654
85 Story2Ames Fire Engine 2
WillB
Henry County
Henry County has no specific numbering for their engines. It's up to each department. Ambulances are A90- A94
This is Des Moines County.
burner50
The Third Variable
NC Iowa
There is no numbering standard across the state. It is up to each county, their "traditions", and what the person who is determining the number want's to do.
Most of the time numbering doesn't make a whole ton of sense.
In the county where I work numbering is separated out by town. Anything with a 100 series is a certain town. 120-130 is PD officers, 150-170 is ambulances, 171-199 is fire. And the same repeats for all towns in the county.
In my home county literally everything is crammed between 1-99. All deputies, LEO's, ambulances, fire apparatus, etc.
In a different county near me, some departments use call signs and all units use the same "county number" when outside of the county.
radioboy75
Rock Rapids, Iowa
I agree with Burner50. Up here in the northwest corner, there doesn't seem to be any county-wide system. Some counties do use numbers, but others just use the name of the truck, like "Little Rock Pumper" or "Lester Tanker." It's much more on tradition. Some of the personnel have numbers. Like the the George, Iowa Fire Chief is "GF-1A". I don't know if the rest of the officers have numbers or not. The Rock Rapids Chief is "F1A." The numbers go down with the rank. Like Assistant Chief is F1B, then there's also F1C and F1D. "F" obviously stands for "Fire," but why the number "1" and then a letter, I don't know. The rest of the chiefs in the county just go by "<town name> chief." In Orange City, I know their trucks are all 84-6X like 84-sixty-three, etc. But there doesn't seem to be any rhyme or reason to it and even less with other communities in the county. I know Sheldon's ladder truck's number is the same as an aerial truck that FDNY lost, as a tribute to that aerial company. It's just a total mixed bag up here, unlike law officer numbers, which, for the most part, are a coherent system in most parts of the state (except for large metro areas where everything is different.)
mws72
l realized there is no standard plan. The State Fair School probably has a recommendation but no requirement. But it seems like most of the counties around me does go with a recommend plan. Maybe if you know of one or not list them on the wiki page for the each county.
K0MSM
Dana, IA
I can provide the station numbers for Green County. Each department has their own system for apparatus numbering.
