Fire Priority Codes
papillon
I think the following is true for most of SW Ontario. Can anyone fill in the blanks or correct these ?
Tim
Priority 1 -
Priority 2 - Slow down, non critical
Priority 3 - Return to base or false alarm
Priority 4 -
Forts
Mentor
Ontario, Canada
Opposite for London.
Code 1 - In service & available
Code 2 - In service & available, but out of their district
Code 3 - Urgent call, but not lights and sirens
Code 4 - Lights & sirens emergency call
Code 5 - Out of service
papillon
Yes opposite. Actually seems to be more logical since it resembles the MOH codes.
Tnx
bwjmackie
Ontario, Canada
For Waterloo Region, I don't believe any such codes are used; just plain English.
Cambridge Fire tends to use "respond" and "proceed" in a manner consistent with "lights and siren" and "no lights and siren" respectively, but that's about it.
papillon
In Windsor - Essex it's different. Priority 3 is definitely "False Alarm , Return to Base"
OK Thanks .
VE3JSO
sarnia ont
and that goes the same with the lambton as well go something like forest station respond to 402 for car fire or something along that line
papillon
Obviously, that's wrong and I received some incorrect information. The codes vary across SW Ontario. .
Some use codes that resemble the MOH , some don't use codes at all and Windsor uses a different system altogether. Based on a call I heard last night, this is how it is here. P1 is the actual initial dispatch which assumes the worst until someone on scene updates.
P2 - slow down / take report
P3 - Return to station.
Will have to pay more attention to Fire calls. Thanks to all that responded.
