Fire tones, What are they, and why are they used?
Wahoos4Life
Rixeyville Va
So since I got my new digital scanner Ive been listening to the fire departments a lot more
and have been wondering what exactly are these TONES that are sent out
and why?
RayAir
If you haven't already read ^ , the tones set off the Minitor pagers fire personnel carry. When the Minitor receives the proper tones, it alerts by rapidly beeping and then the Minitor's squelch opens up and the dispatch call comes through.
The purpose of being able to program fire tones on a scanner is to prevent your scanner from receiving other departments on that frequency or other transmission not related to the dispatch call. It's been a while since I had a Minitor, but I think you can press a button on the pager to turn off the Alert only (tone-out) function. It then operates like a scanner or receiver.
alanlungs2
Tones
Tones are used for more then setting off pagers.. Then sound sirens, Horn, turn on lights in stations.
avfd2922
Kentucky
The tones are used for voice pagers which is the main way most volunteer firefighters are alerted to emergencys. They are also used to alert manned firestations. Some are even setup to open the bay doors and turn on lights inside the stations.
Eng74
Kern County, CA
The tones are used for voice pagers which is the main way most volunteer firefighters are alerted to emergencys. They are also used to alert manned firestations. Some are even setup to open the bay doors and turn on lights inside the stations. Sure you already have your answer but the others are kinda funny though. Hmmmm, tones or tons.
I know most stations that have the tone out set up to open the bay doors that switch always get thrown so it does not happen. If you are out in the area or they do an "all call" the doors open and then the station is open and things start walking away.
W6KRU
Vista, CA
That's pretty sad but says a lot. :evil:
KF0SKV
Northeast Nebraska
The tones at my department basically does the same as at most other stations. Alerts us to a call and activates the outside siren.
