Firmware Issue XG-100P
n9ihx
Chicago Area
Have an XG-100P thats a friends which apparently needs a firmware upgrade its running 4.3.11 according to the software.
Read somewhere that you can't just dump the latest version in you have to step it up to current versions wondering if this
is correct? Also wondering if anyone might have the firmware files so I can upgrade this radio?
Greg
northstarfire0693
North Carolina
I dont know about having to "step" it. I have never heard of that with a XG. However, I could be wrong. With a lower FW version I am willing to bet he is running RPM 10. If you upgrade to the latest, you will need RPM 14. R06T02 is the latest and from what I am told you will need RPM14.
Someone correct me if I am wrong.
n9ihx
Chicago Area
Have RPM 14 it runs on that no problem just wondered if I needed to up it in steps? I read somewhere maybe here that was the process.
Forts
Mentor
Ontario, Canada
4.3.11 doesn't look like a valid firmware version unless it's *really* old. I would double check that. I've seen the odd 100P pop up with pre XGP firmware that can't be upgraded (or not easily at least). You should be looking for a firmware version of XGP R0xxxx.
n9ihx
Chicago Area
It was original really old firmware in a radio that is mint looks like it was never used. Thanks all for the replies I got it upgraded and it’s working fine.
prcguy
On older XG-100Ps you have to be careful with old hardware where the keypads can get intermittent. I look for hardware version R20 if possible and avoid anything before R13.
merlin
DN32su
I think the OP has confused a burnapp version with firmware version.
By all means, the latest firmware for portable is XLPR06T02.
And use RPM 14 to upgrade. A few have upgraded from some of the earliest firmware, and done it in a single step
with no problems.
These are not like Motorola where you need a certain CPS and increment your upgrades.
merlin
DN32su
Intermittant keypads are always hardware issues. Firmware won't fix that. some early firmware did have keypad and display issues,
but not intermittant.
One of the TSMs explains a fix.
TDR-94
And the keypad issue affects all hardware revisions of the XG-100P. It's the terrible keypad design of the front covers.It has nothing to do with the hardware revisions that you see on the radio information screen.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
It may not matter but at least you know they are newer and may last a little longer before failing.
TDR-94
Yeah, it's possible a less used one might prolong the issue.
When one of mine went to L3HARRI$ for repair, they replaced the front cover with a new one and about 9 months later the keypad started becoming problematic. That one and another are newer revisions of the radio and both now have the keypad issues.
All are also loaded with the last revision of firmware.
KI4IHC
I just got an XG-100P that seems to be on this ancient 4.3.11 firmware - did you have to upgrade in steps, or were you able to just upgrade directly to the latest fw?
Additionally, can anyone point me in the right direction to get my hands on the firmware?
I do have RPM14, but not sure if there is other software I need to track down as well to install the upgrade.
n9ihx
Chicago Area
I did step it up but I don’t believe that it was necessary to do so. I didn’t do every version just a couple lol.
Forts
Mentor
Ontario, Canada
Personally, I would go in steps. The earliest version of the XGP firmware for the Unity that I have is R02A26. I would try flashing it to something around that vintage, then jump up to the latest R06 code.
The encryption modules are a little out of date, but really not a big deal for hobby use.
KE7TR
Vail, AZ
Hello to the forum! I am new to the XG100 forum. I have a pair of XG-100F radios. I read with interest that there is a firmware upgrade path, but saw the caution about hardware- Looks like the radio I have handy has digital hardware revision 11. Current software is XLPR06M03.
How do I go about finding what is the optimal software upgrade for the hardware? Thank you for your time and assistance,
