Firmware Updates Info ONLY
kd4efm
EL98 Florida
screenshot is what I was sent. Sorry.
I don't have any access to the provided information.
NX-5000
NX-3000
KPG-D3
W0VNE
Minnesota
I'm trying to hunt down firmware for the Version 3 5100 Handhelds. *The ones that use a Motorola UCM for Crypto. I've trying to help out a guy who has two of these that have version 3.2.2 and are boot looping. I can communicate if I act fast enough with PCIssue to read the options / esn and with Tune got a read on the radio but... When I power up with the 3rd button held down to go into Bootload mode it comes up fine (Doesn't reboot over and over) but get communications error if I try to update the Firmware. Which make no sense since I can read / write with PCIssue and PCTune if I act fast (Right after the logo is displayed) Anyway the only ver 3 firmware I have is CU_5100_Application_boot_Ver_03_10_06.exe I don't see many version 3 5100s so I am not sure I've ever used it but wonder if anyone has any other version 3 or the same one as mine but is not 9,860 KB?
kd4efm
EL98 Florida
FYI, No updates at this time other than the Trunking 2.5 firmware.
kd4efm
EL98 Florida
12-01-25
Updates to the following:
Firmware
NX-1000, DMR - NXDN 2.37
NX-3000 4.31 - dmr t3 fixes, indoor location adjustments
NX-5000 5.31 - dmr t3 fixes, indoor location adjustments
NXR-1000 2.40
Software
D1 5.30
D7 2.31
Check with your local dealer for more details.
wsp44
NX-5000 6.0
NX-3000 5.0
Both require KFL 1.30 to load them which will load the old KEX file and new KAX file
Maybe @kd4efm can get some SRN for the new FW
R_Rabbit10
When can we expect the 6.0 to be released in North America?
This is for the 5.31 firmware:
Rev.VersionChecksumMod. DateS/No.TypeItemDescriptions / Corrected errorsRemarks
64K5.31F3202025-NOVC5B~ALL
ALL
ALL
Update
Hardware
DMR Trunking
Added the following Function
- Indoor Location
Substitute for Varicap Diode
Priority Monitor not working on All Call.
Works with Only the KPG-D1 V5.30 or later
Horizontal application of QI for NX-3000
wsp44
ALL
ALL
Update
Hardware
DMR Trunking
- Indoor Location
It already is
AM909
Radio/computer geek
SoCal
I, too, see firnware v6.00 for NX-5200S etc., v6.00 for NX-5200 etc., and v5.00 for NX-3200 etc., on both mytools and mytools-legacy, released December 22.
Cortexian
Viking Subscriber Software 25.2 Point Release 1
Release Date: November 20, 2025
Title: FSN-1125-VIKING-42
Overview
This Field Software Notice (FSN) announces the KENWOOD Viking® Subscriber Software Version 25.2 Point Release 1.
IMPORTANT: We recommend all Armada Server users update to version 1.46.14 (this release).
Software Versions
The following table lists the Viking Software items, and corresponding versions included in the 25.2 Point Release 1.
Item​
Version​
Armada Client
1.46.14​
Armada Server
1.46.14​
Armada Server Demo
1.46.14​
VP8000 Firmware Image
8.46.15​
VP5000/6000 Firmware Image
8.46.15​
VM8000 Firmware Image
8.46.15​
VM5000/6000/7000 Firmware Image
8.46.15​
Issues Addressed
The following table lists the customer-impacting issues resolved in the 25.2 Point Release 1.
Issue​
Overview​
Armada Crash with Many Multi-Deck RadiosAn issue has been resolved where Armada crashed when scanning a database containing many Multi-Deck radios.
Unable to load Hardware ARC4 keys without SCMAn issue with loading Hardware ARC4 keys without the SCM has been resolved.
Repeater TA Incorrectly Uses the Tx RANAn issue with the Radio in repeater TA mode incorrectly using Tx RAN has been resolved.
VM8K Keyloader Detach CrashAn issue with VM8000 crashing when the keyloader cable is disconnected has been resolved.
Invalid Key display in DMR/NXDN ScanAn issue with invalid key displaying in both NXDN and DMR during Scan/Radio Wide Scan has been resolved. The invalid key display was related to a default Key ID Restriction in DMR/NXDN scan.
Customer DMR Site Roaming Scan List CorruptionAn issue with Customer DMR Site Roaming Scan List corruption after moving around channels has been resolved.
KCH19/21 No Volume Control in Keypad LockoutVolume can be adjusted now in keypad lockout. Two new check boxes have been added to override the keypad lockout settings.
VP5430 and VM5930 Replacement PartsArmada will restrict firmware downgrades for new VP5430 Portables,
and VM5930 Mobiles due to software changes to support a part supply change. Radios manufactured after November 2025 will be restricted to 8.46.15 or newer.
Don't see the 25.2.3 yet.
