Firmware Upgrade
RadioKid604
Vancouver, BC
Trying to upgrade the firmware on my DM3401, but am having an issue. The current version is R01.01.00, and I am trying to update to R01.12.17. I have already installed the update to my computer. I get to the update screen in CPS, but cannot see the desired firmware on the drop down menu to upgrade. It has nothing to click. What is wrong here?
Thanks!
N4KVE
PALM BEACH, FLORIDA
Ignoring the fact that it's an Euro radio, people who have upgraded the NA version from such a low FW version have stated it can't be done in 1 jump. They had to first upgrade to 1.06, & from there to 1.12.17.
Forts
Ontario, Canada
I helped a fellow member do his a few days ago, and he went straight from 1.00.02 to 1.12.17 with zero difficulty,
I'm sure the OPs issue is a region conflict... trying to load NA firmware with EMEA CPS.
RadioKid604
Vancouver, BC
The radio reads and writes fine with the emea cps that I have. I'm not sure if the firmware I have is emea or not, it's just what came with cps so I'd assume it would work. How could I try it with North American firmware?
KG4INW
Midlothian, VA
I don't have access to EMEA FW (it used to be hosted on another forum that no longer exists), only NA FW and while looking at them, their file names end with NA (before .exe). Check to see if it's for the correct region.
ETA: I believe the only way to get different region FW in to it would involve using software that's not allowed to be discussed here (Motorola proprietary) which would then require you to change the model number (and thus the region) followed by subsequently using NA CPS. I wouldn't bother.
RadioKid604
Vancouver, BC
I don't think it says NA in the title, I will check again when I get home later. Would it work to try NA firmware on it as it stands now?
RadioKid604
Vancouver, BC
Checked the files, they don't have an NA at the end. The folder is actually labeled "EMEA FW". The file I'm installing is called "MOTOTRBO_R011217_130203_DM3xxx.exe"
Would it work if I just tried installing NA firmware on emea cps as it stands now?
N4KVE
PALM BEACH, FLORIDA
Strange, as RO1.12.17 is the newest, & last FW upgrade for the Gen 1 radios.
Forts
Ontario, Canada
No, it won't work. The EMEA CPS won't let you load NA firmware.
