SDS100/SDS200: Firmware V1.23.03 is out
n1chu
Farmington, Connecticut
That's the point, Sentinel won't download 1.23.03 for me and says 1.23.01 is the latest version. Don't know what the hell is wrong.
Are you using the correct Sentinel? Isn’t there two versions? One for HomePatrol and another for the SDS100/200? Did you install the newest edition of Sentinel? When I went after 1.23.01 Sentinel informed me I first needed to update Sentinel. I did and then was able to download 1.23.01… both Main and Sub updates…and later 1.23.03. I believe only the Main ver was pushed.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
In the post prior to yours I describe how it's been sorted out already. I had already updated to 1.23.01 so Sentinel wasn't the issue.
n1chu
Sorry but I don’t see a prior post. But happy that you’ve got it sorted out. What did you find was causing the problem?
kruser
Well Known Member
W St Louis Cnty, MO
Look one page back for post #60
n1chu
And my VHF/UHF reception has shown a marked improvement too! -looking for verification on that point… it may just be me, happy to get my truck back from the autobody shop after 3 weeks. But the new firmware seems to be enhanced. Comments?
pro106import
Milford, Ct. perched high above Long Island Sound
Same here. Much improved. And it scans now and stops on weaker signals when the squelch is closed to #2. With the old firmware, the squelch was too tight at #2 and would miss many transmissions if they were worse than -90db strength. I complained about this for years and many on the forum argued with me, suggesting that my signal was too low ect... UHF conventional much better also. I reverted back to version 1.21.00 just to make sure I wasn't imagining things. After a quick verification, I quickly updated back to the latest once again.
n1chu
Good to hear!
jgorman21
Glenmont N.Y.
Well… I did my SDS 100 yesterday. So far so good. Not really seeing any problems or “improvements!” I’ll have to look around and make sure that all the settings remained as they were.
VA3ADP
Mississauga, Ontatrio Canada
I am happy to report the new update has drastically improved my reception! I am super impressed with the Uniden R&D team and BearcatJoe for this quick fix! Thanks again!
crippledchicken
Butler County MO
After the latest update, I had to change the filters. I found normal filter to perform the best now, instead of wide invert. My squelch seems the loosest when set to normal filter and squelch at 2. So the filters may, be worth re- investigating.
k3rsj
ARNOLD
I called UNIDEN Support and it seems it's the first they heard of this problem. Everyone call @ 1-800-297-1023. I recommended Sentinel be enabled to retain previous version of firmware in case this happens again. I borrowed "$700 brick" and it seemed effective. The lady said she would escalate immediately. I recommended redistributing earlier version firmware to Sentinel for an immediate fix. She wrote it all down. We need more complaints!
donc13
Grand Junction, CO
I'm sorry, but we're not your backup singers.
Whiskey3JMC
RTFF
Southeast PA 🇺🇸
