Does anyone have any idea when the the first train(s) started using radios? Like when/where? I would be curious to see articles or info about this.
<< THIS >> might interest you.
Wow I never would have even thought of that, swapping radios to get different channels. Very interesting.One interesting tidbit I leaned is that the concept of run-through power (on the head end) as we know it today didn't really happen until around the 1990s, with the advent of all-channel radios. Previously, radios had no more than 4 or 8 channels which were limited to the frequencies of the home railroad. If a train was being run through (for example, trains from the TP&W at Logansport, IN to Columbus, OH via the Penn Central), a unit of the receiving railroad had to be stuck on the head end of the train or the radio shop had to swap radios. It was lots easier to simply stick (and keep track of) a locomotive on the head end.
That was part of the reason for the development of the Clean Cab Radio; a common tray and connectors to make the swapping out of radios relatively easy. Different manufacturers could make a radio to the same specs and it would work on a Conrail, C&NW or Santa Fe engine.One interesting tidbit I leaned is that the concept of run-through power (on the head end) as we know it today didn't really happen until around the 1990s, with the advent of all-channel radios. Previously, radios had no more than 4 or 8 channels which were limited to the frequencies of the home railroad. If a train was being run through (for example, trains from the TP&W at Logansport, IN to Columbus, OH via the Penn Central), a unit of the receiving railroad had to be stuck on the head end of the train or the radio shop had to swap radios. It was lots easier to simply stick (and keep track of) a locomotive on the head end.
what about the programming software? Is it DOS based?I can get one...FOR FREE!!!!!!!!!!!!!
Interesting yes, so when was the AAR standard channel plan invented? and railroad radios came pre-programmed with the standard AAR channels to selection?
Sorry for the delay...I've been BUSY!!!!! I can get a radio shop copy, the DOS, unknown. Uh, and it's JEM Corp...my badwhat about the programming software? Is it DOS based?
This is really cool, I'd never even heard of induction telephone before seeing this. Do any ham guys still use something similar today?Not really radio, but...
Linked together . . . by Induction Telephone | Pennsylvania Railroad, 1945
Source
When I was working for Conrail in North Jersey we had the following frequencies: 160.800 Road 1, 161.070 Road 2, 160.860 channel 3 (yard), 160.980 channel 4 River Line, and 160.245 Oak Island Hump. 161.400 was NJTransit for jobs that went on NJTransit to switch industries, etc.When I hired on with Conrail in November 1976, I thought they only used two channels. Channel 1 Road was AAR 46 (160.800 MHz) and Channel 2 Yard was AAR 64 (161.070 MHz). You could sit in the Logansport yard office and hear the dispatchers out of Fort Wayne on the Road channel talking to trains on the Michigan Branch around Marion. We really didn't think radio congestion was any big deal.
When I moved to Indianapolis in May 1977, I learned that Avon Yard was on Channel 4, AAR 58 (160.980 MHz), though Hawthorne, Transfer, and Hill Yards used Channel 2. Since most crews still used hand signals when switching, there wasn't much radio traffic. But, I always wondered about Channel 3 which was AAR 50 (160.860 MHz). Sometimes, yard crews would use it if they wanted to work without interruption from other crews. But, that was it for Conrail in central Indiana--just four radio channels.
Things are a lot different today. A 4-channel scanner just isn't enough anymore.
