My display flickers. I’d like to send a video clip but haven’t figured out how to do that or even if this forum’s format allows… hoping someone can advise if it’s possible to send a clip.
The flickering seems to remain at the same rate and occurs in all of the different display options. The flickering does not seem to get progressively noticeable, it will flicker at the same rate from when I turn the SDS200 on and continue as long as the radio is left on. Long periods of non-use, power off, does not correct the problem.
The scanner itself is one of the first distributed… I pre-ordered it (if memory serves, Scanner Master) and waited for it to become available. The scanner performs as advertised other than the flickering.
