SDS100/SDS200: Flickering display SDS200
n1chu
Farmington, Connecticut
My display flickers. I’d like to send a video clip but haven’t figured out how to do that or even if this forum’s format allows… hoping someone can advise if it’s possible to send a clip.
The flickering seems to remain at the same rate and occurs in all of the different display options. The flickering does not seem to get progressively noticeable, it will flicker at the same rate from when I turn the SDS200 on and continue as long as the radio is left on. Long periods of non-use, power off, does not correct the problem.
The scanner itself is one of the first distributed… I pre-ordered it (if memory serves, Scanner Master) and waited for it to become available. The scanner performs as advertised other than the flickering.
rf_patriot200
Freeport, Illinois
Just curious, Are you using the supplied wall wart, or a Switching Power Supply ?
rhodester
Saratoga County, NY
Sorry it came back.SDS200 Flickering display
n1chu
I see I posted the same issue back in 2020. I wasn’t sure I did and posted again. So far, no one seems to have suffered the same flickering problem. I guess it’s time to send it in for repair. Thanks for the help.
rf_patriot200
Freeport, Illinois
I wonder if the flickering, would have anything to do with the supplied wall wart, rather than the SDS 200 itself ? Has anyone bothered to test their power supply ? I power mine using a Alinco DM-330mv with no Flickering since 2019.
crippledchicken
Butler County MO
Mine has never done it since 2019 yet, anyway! I think I would check the ribbon cables though as my first suspect. When I did the Static Discharge mod in 2019 I made sure ribbon cables were reseated well.
