Florida Forestry - Master Thread
tampatracker
You'll need to make sure the Fire-Tac service type is turned on (tag column below). It is not enabled by default out of the box on the SDS100. The TRX-1 doesn't discriminate traffic by service type like the Unidens do which is likely why you're hearing traffic on the TRX
Region 3 - District 14 Lakeland Forestry District​
Polk, Hillsborough, and Pinellas
FrequencyInputLicenseTypeToneAlpha TagDescriptionModeTag
159.330151.2275KIH457RM08C NACLakeland P25Region 3 District 14 P25P25Fire-Tac
159.330151.2275KIH457RM107.2 PLLakelandRegion 3 District 14FMFire-Tac
Region 4 - District 15 Myakka River District​
Manatee, Desoto, Hardee, Sarasota and Charlotte
159.240151.3175KIH925RM110.9 PLMyakka RiverRegion 4 District 15FMNFire-Tac
159.240151.3175KIH925RM96 NACP25 Myakka RiverRegion 4 District 15 P25P25Fire-Tac
Region 3 - District 11 Withlacoochee Forestry Center​
Citrus, Hernando, Lake, Pasco, and Sumter
159.225KNIC466BM06E NACWithlacooche P25Region 3 District 11 P25P25Fire-Tac
159.225151.385KNIC466RM88.5 PLWithlacoocheeRegion 3 District 11FMNFire-Tac
Yes, I've enabled all service types. Still nothing.
tampatracker
Here it is. I hope it is readable let me know if I sent it wrong. TY
  • FORESTRY.zip
bravo14
Polk County FL
Did you setup quick keys? I just opened it in proscan and shows none for quick key. I noticed the location is on also. I usually turn that off when scanning local stuff when on road trip I turn location on while using the gps puck.
bravo14
Polk County FL
Let me know if this works? I disabled the location and did quick keys you can change the QK.
  • FORESTRY.zip
Whiskey3JMC
Surfer of the Delaware Valley Airwaves
Simulcastylvania, TE
Quick keys aren't required for the ability to scan a system/conventional channels/etc.
I did notice however that the FL wasn't set to monitor via EDIT > EDIT PROFILE in Sentinel, or on the scanner itself: MENU > SET SCAN SELECTION > SELECT LISTS TO MONITOR so you'll need to do that and upload it back to your scanner. It won't let me make the modification and re-import it, as it changes back to monitor "off" for some reason...
tampatracker
OK thanks bravo this is your file as placed in FL#53 in Sentinel. How does it look? Also monitor "on" is now set.
  • 53 FORESTRY.zip
bravo14
Polk County FL
I opened it in proscan. Looks good. You can try in the morning when they do radio checks. Atleast on the FL QK list you can choose any number.
kd4efm
EL98 Florida
I will be working on the p25 simulcast, other than a beacon, you should hear things fine.
tampatracker
What time in the morning are radio checks performed? I'm going to set up my second SDS100 next to the TRX to exclusively monitor the forestry freq's to see what happens. I haven't had time to sit and listen on the SDS for a random transmission, so I want to nail it down. Thanks again.
bravo14
Polk County FL
Should try 7a-10a
wtp
Port Charlotte FL
i was traveling through Tampa around noon and did hear a short talk on 159.33.
but i was in search and caught no tones or nacs.
tampatracker
Okay I still haven't received anything on the sds100 on forestry just curious does anybody else with an SDS 100 out there received them on p25?
trooper890
N/A
All the SDS models receive forestry fine. Keep in mind its a mobile coverage system, you may/may not get much on a handheld inside a building. Isn't always a ton of traffic on it outside radio morning checks done in most of the districts and fire weather forecasts unless something is going on in the district. Then, you'll get some traffic until they get on scene and go to an FM tactical.
It is an old way of doing business (including the constant reading of mobile callsigns that no one else has done in 30+ years). It works for them but doesn't always lend itself to listening from afar or compared to monitoring a modern system designed for portable service.
tampatracker
Okay thanks for that
