FMP scanning problem
sameehosen
HAMPORG
Thank you
When you play FMB get this error
rtlsdr_demod_read_reg failed with -2
rtlsdr_demod_write_reg failed with -2
rtlsdr_read_reg failed with -2
rtlsdr_write_reg failed with -2
No supported tuner found
Enabled direct sampling mode, input 1
rtlsdr_write_reg failed with a
It remains in this state to close
Marco192
Hi guys ... I don't want to start another topic with the same subject.
I am having the same problems as described in this topic ... when using fmp to scan dsd+ won't hold the frequency as it should when it detects digital voice.
I have checked for things suggested here ... dsd path in fmp.cfg and also the formatting of the fmp.scanlist (it's like this: 150.000 DMR description).
What else can I do to fix this ... please help!
Thanks!!
Marco192
Hm, maybe post (copy/paste) the actual .cfg and .ScanList files? Someone might spot something.
hope that someone has an idea. btw. i tried downloading a fresh copy of dsdplus from dsdplus.com ... no luck
here is fmp.cfg:
1 ; sampling rate (1.0, 2.0 or 2.4)
512 ; spectrum window width
32 ; FFT size (8k, 16k, 32k)
10 ; spectrum update rate in Hz
5000 -6250 7500 12500 15000 25000 ; step size table; units = Hz; negate default
. ; DSD+ path
.\FMP-FreqList.csv ; primary frequency list CSV path\filename
.\FMP-FreqList2.csv ; auxiliary frequency list CSV path\filename
miles ; search units (miles or kilometers)
99.9 ; search distance
19.7163 -155.6241 ; search origin
here is ti FPM.ScanList:
165.7 DMR test 1
166.425 DMR test 2
167.51875 DMR test 3
154.1625 DMR test 4
<EOF>
