FMP24 version
kd5dga
Killeen,Texas
I am a regestered DSD Plus Fast Lane user and I tried to use DSD Plus UI and the UI says not a fastlane FMP24. How would I know what versions do I have? The DSD Fast Lane shows I am running the latest version.
Reconrider
Inside the Galaxy
Radio Galaxy
Never heard of this "dsdplus ui" until now.
DSD+ fastlane is paid, do you remember paying for the software?
It's possible you didn't update to the latest version of the the files via email / the new update downloader added a few versions back.
AJAT
Navajo County AZ
Try moving the base files back into your DSDplus folder. I think you can re download them from the update option. Make a backup of everything first. I had the same thing happen to me, I forgot what exactly I did to fix, I know I did try that. Once I did get it working I did not find very useful, but then again maybe I just did not give it enough time to play around with it.
kd5dga
Killeen,Texas
Here is the link to DSD Plus UI.
DSDPlusUI - The best and only GUI for DSD+ - dsdplusui.com
I bet you are correct when it came to the later updates. I did not run DSD Plus FL for a long period of time until lately.
slicerwizard
Toronto, Ontario
When you run FMP24, the version number is displayed in the console window.
If you're out of date, you should use the DSD+ Misc menu's entries to update your copy of DSD+ and to grab the latest base files. Copy all the DLL and exe files from the base files zipfile to your DSD+ folder.
kd5dga
Killeen,Texas
Once again you have the answer. I will do that shortly.
Annunaki
The message you are getting is only triggered when using the Public build, so please be sure you obtain the updated base files for the Fastlane build, like @slicerwizard has suggested.
For some odd reason, I don't support the Public builds, I do see this as a bit strange myself and I will try to include support in the future, Maybe...
kd5dga
Killeen,Texas
I should have posted earlier. After I did the file update to DSD PL and installed the latest for DSD FL then UI worked great.
PhillyPhoto
Wethersfield, CT
Look like it may be broken again. I just redownloaded the latest base files, and FMP24 is version 2.81, with a date of 5/31/2022. I'm still getting the message "Not the Fast Lane FMP24.exe or is an Ourdated (sp) Version". I also checked for an update within DSDPlusUI and it says 2.3.7.9 is the latest.
Annunaki
Thanks, yeah FMP24 2.76 is currently only supported in DSDPlusUI 2.3.7.9, however I have been working on a version which supports multiple FMPx versions for both DSD+ FL and PR, I will push some sort of release later this evening but there may be some small bugs.
