For UPMan
milcom_chaser
Good Day,
We can't seem to get our 325P2 Firmware Ver. 1.07.09 to display both Color Code and Slot # at the same time during a service or
custom search. We have toggled tone/code search to NAC/Color Code, which at least gives us the Color Code when it's on, and DMR type when it's off.
Up on the TWiki it says:
Ref: http://info.uniden.com/twiki/bin/view/UnidenMan4/DigitalMobileRadioUpgradeforBCDxxxP2
DMR Reception in Custom or Service Searches
During a search, when the scanner stops on a DMR transmission, the following information will be displayed:
•DMR -- for DMR One-Frequency systems. The scanner will also display the current slot number (S1 or S2) and the received color code.
•CON -- for MotoTRBO Connect Plus systems. The scanner will also display the current slot number (S1 or S2) and the received color code.
•CAP -- for MotoTRBO Capacity Plus systems. The scanner will also display the current slot number (S1 or S2), and the received color code.
•DT3 -- for DMR Tier III Trunked system. The scanner will also display the current slot number (S1 or S2) and the received color code.
We've noticed when scanning a single freq DMR, if you toggle the display mode option Func + 6,
the following will be displayed:
Mode 1: ID + Frequency
Mode 2: ID + Color Code
Mode 3: ID + Slot #
Yet, as per the TWiki description, when we do a custom or service search, were not seeing Color Code and Slot number displayed at the same time.
Are we misinterpreting the description on the TWiki, or are we missing a setting here.
Thank you for taking a look into this.
